You are here: PSPad forum > English discussion forum > Re: Default Project
Posted by: Shadeclan | Date: 2013-01-04 15:58 | IP: IP Logged
I don't use PSPad projects much but I was wondering if there was a way to set a default project so that when PSPad was started, that project would appear instead of an empty project.
Posted by: pspad | Date: 2013-01-04 19:11 | IP: IP Logged
There is no "Default" project, but PSPad remembers last used project and will open it next time when you start it.
Condition - program settings / Files - Save Work / Desktop set to any state except Don't restore files
Posted by: KennyT | Date: 2013-03-15 09:54 | IP: IP Logged
This feature does not seem to work? I have two projects ("A" with loads of files, "B" with a few), regardless of which project I have open when I exit, PSPad always opens project "A".
My "save work/desktop" option is set to "PSPad opened files only".
Please advise
K
Posted by: pspad | Date: 2013-03-17 12:02 | IP: IP Logged
Ensure you have write rights to file Recent.ini.
Last open files and last open project are stored in Recent.ini file in [SaveWork] section
Posted by: KennyT | Date: 2013-03-19 12:48 | IP: IP Logged
I have write access, but no [savework] section?
[Find files config]
Search where=2
Search directory=c:\duk6
Subdirectories=1
Clear results=1
File masks=*.for
Search text=bht
Replace text=
Ask replace=0
Case sensitive=0
Whole words=0
CodePage=0
[Find/Replace config]
Case sensitive=0
Whole words=0
Ask replace=0
Add LineNum=0
Entire Scope=1
RegExp=0
[Color Selector]
shStore1=15790320
shStore2=15790320
shStore3=15790320
shStore4=15790320
shStore5=15790320
shStore6=15790320
shStore7=15790320
shStore8=15790320
[Clip Window]
Height=165
Width=344
[Find files find history]
Item0=bht
Item1=programme path
Item2=lq_Depths
Item3=Q_ClassEntries
Item4=iactemp
Item5=qqrad
Item6=2100
Item7=M_FLD+IRT*3-2
Item8=Q_ClassShow
Item9=io_archive
Item10=archive
Item11=enablelog
Item12=real function
Item13=recall
Item14=F4
[Find files directories]
Item0=c:\duk6
Item1=c:\wlib
Item2=c:\duk6;c:\wlib
[Find files masks]
Item0=*.for
[CommandLine]
Item0=c:\win32app\salford\ftn95 %file%
Item1=\wlib\wlib.bat
Item2=\rep5\wlib.bat
Item3=\duk6\duk6\wlib.bat
Item4=wlib
Item5=c:\win32app\salford\ftn95 %file
Item6=c:\win32app\salford\ftn95 %1
Item7=c:\win32app\salford\ftn95 &f
Item8=c:\win32app\salford\ftn95 %%1
Item9=ftn95
[Recent Projects]
Item0=c:\senergy\LogicomEP.ppr
Item1=C:\senergy\Senergy.ppr
Item2=C:\duk6\Duk6\LogicomEP.ppr
Item3=C:\Users\kenny\Documents\Logic.ppr
[Find/Replace find history]
Item0=NMR_ENV
Item1=LQ_MAIN
Item2=nmr_lq
Item3=date
Item4=LSTOP
Item5=IO_ChStatsW
Item6=WF_PPlot
Item7=pistr
Item8=wcap
Item9=dsp
Item10=dsp%
Item11=936
Item12=70
Item13=dsp%d
Item14=acq%wfc
[Find/Replace replace history]
Item0=IPI_GetI8
Item1=IPD_
Item2=E IPD_
Item3=E IPL_
Item4=long
Item5=long
Item6=0
Item7=,
Item8=IP_ICurve_GetIndex1
Item9=C:\Logicdata\Thelma_i-files
Item10=I8CO
Item11=CBUFFI(
Item12=UU_WKOUT
Item13=UU_X
Item14=STR1
[Recent]
Item0=C:\duk6\modules\AN_MOD.FOR
Item1=C:\wlib\BDSCCOM.INC
Item2=C:\duk6\Duk6\cm_main.for
Item3=C:\duk6\decode\dec_dlis.for
Item4=C:\duk6\decode\DEC_MAIN.FOR
Item5=C:\duk6\decode\dec_qdl.for
Item6=C:\duk6\decode\DEC_QDS.FOR
Item7=C:\wlib\NWLIB.FOR
Item8=C:\senergy\Senergy_dummy.for
Item9=C:\senergy\senergy_main.for
Item10=C:\senergy\Senergy_Wrappers.for
Item11=C:\senergy\Senergy1.for
Item12=C:\senergy\Signatures.txt
Item13=C:\senergy\test_senergy_main.for
Item14=C:\senergy\test_senergy_sub.for
Item15=C:\Users\kenny\AppData\Local\IntPetro41\UserPrograms\Logicom_Launcher_CSharp\UsersCode.cs
Item16=C:\duk6\Duk6\LQ_INT.FOR
Item17=C:\duk6\Duk6\wf_env.for
Item18=C:\duk6\Duk6\wf_func.for
Item19=C:\duk6\Duk6\LQ_FUNC.FOR
Item20=C:\duk6\Duk6\lq_test.for
Item21=C:\wlib\A_ENV.INC
Item22=C:\wlib\a_csv.for
Item23=C:\duk6\IOLIB\Io_func.for
Item24=C:\wlib\W_TEST.FOR
Item25=C:\duk6\Duk6\WF_POPS.FOR
Item26=C:\duk6\IOLIB\IP_Func.for
Item27=C:\duk6\Duk6\duk_6.for
Item28=C:\duk6\Duk6\LQ_MAIN.FOR
Item29=C:\duk6\Duk6\APP_MAIN.FOR
Item30=C:\duk6\IOLIB\IO_INIO.FOR
Item31=C:\duk6\IOLIB\IO_LDIO.FOR
Item32=C:\duk6\IOLIB\IO_MAIN.FOR
Item33=C:\wlib\NLIB.FOR
Item34=C:\duk6\IOLIB\IO_MISC.FOR
Item35=C:\duk6\IOLIB\io_wells.for
Item36=C:\duk6\Duk6\kkk.for
Item37=C:\duk6\IOLIB\io_test.for
Item38=C:\duk6\IOLIB\IO_CHANS.FOR
Item39=C:\duk6\modules\d_type.for
Item40=C:\duk6\Duk6\DUKPET.FOR
Item41=C:\duk6\Duk6\yy_mod.for
Item42=C:\duk6\Duk6\WF_MAIN.FOR
Item43=C:\duk6\Duk6\WF_LOG.FOR
Item44=C:\duk6\Duk6\WF_SPEC.FOR
Edited 1 time(s). Last edit at 2013-03-19 12:49 by KennyT.
Posted by: LucyFan | Date: 2013-07-15 18:52 | IP: IP Logged
Hi
My "save work/desktop" option is also set to "PSPad opened files only" and PSPad never opens the project that was open when I PSPad closed.
Is this issue being worked on as I would like to use projects.
John
Posted by: pspad | Date: 2013-07-15 19:24 | IP: IP Logged
It's strange, cause project has bigger priority than files. PSPad should open last used project when you start PSPad only (without file as parameter).
