You are here: PSPad forum > English discussion forum > Scripts Menu missing !!!!
Posted by: Manfred62 | Date: 2013-04-06 11:28 | IP: IP Logged
carbonize:Restricted is normal and admin is when used as admin yes? If so I'm wondering if it's more an issue with not having access to that folder when not running as admin.
Hmm, you mean the PSPad/Script folder? Didn't changed anything on access rules of folders.
All my portable programs are on a separate partition, together with all my other own files.
D:\Eigene Dateien\Programme\...
Maybe I can overcome this with a classic installation (multi user) of PSPad?
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-06 11:52 | IP: IP Logged
No as I'm running it from a backup partition and it's working fine.
When running under normal is the Integrated Scripting Support ticked as running as admin may make it use different settings.
Carbonize
Posted by: Manfred62 | Date: 2013-04-06 14:17 | IP: IP Logged
carbonize:...
In PSPad settings WSH is checked.
The Windows settings? I will check the settings in IE under 'Extras - Internetoptions - Security' and compare them.
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-06 20:55 | IP: IP Logged
I meant when running PSPad under admin there is a possibility it is using different settings so when running it as a normal user check if scripting is enabled in PSPad then as well.
Carbonize
Posted by: Manfred62 | Date: 2013-04-07 12:53 | IP: IP Logged
I'm running PSPad portable, so there's only one ini inside program folder. Also WSH scripting is enabled under both (admin and normal) user.
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-07 13:58 | IP: IP Logged
Hmmm most perplexing.
Carbonize
Posted by: carbonize | Date: 2013-04-07 13:59 | IP: IP Logged
Could it be the antivirus preventing it?
Carbonize
Posted by: Manfred62 | Date: 2013-04-07 15:04 | IP: IP Logged
carbonize:Could it be the antivirus preventing it?
I use Avast (free version). Tested it (stop it temporary), but no success.
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-07 16:05 | IP: IP Logged
Make a new account on the computer, set it as a regular user and see if it has access or not to scripting.
Carbonize
Posted by: Manfred62 | Date: 2013-04-08 15:19 | IP: IP Logged
Good idea. Tried it, but also no scripts available as regular user..
PSPad 4.5.9 (2525)
