You are here: PSPad forum > English discussion forum > Scripts Menu missing !!!!
Posted by: carbonize | Date: 2013-04-03 17:53 | IP: IP Logged
Sure you ran ElevatedShortcut.exe from the Windows 7 folder?
Carbonize
Posted by: Manfred62 | Date: 2013-04-03 20:32 | IP: IP Logged
Yes, tried ElevatedShortcut.exe from several directories. No sucess. The comments for this tool are also ambivalent. Waste of time in my eyes.
Hmm, curiously other editors (Sublime, Notepad++..) can be used as portable with Emmet without any hassle (admin rights...).
Never mind.
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-04 08:00 | IP: IP Logged
Notepad++ uses Python for it's scripting, SynWrite has Emmet built in. PSPad uses Windows built in scripting but still not sure why your windows insists on admin rights all the time.
Carbonize
Posted by: Manfred62 | Date: 2013-04-04 15:43 | IP: IP Logged
Sure, I also want to know what causes this problem. But no time to investigate this deeper.
Since my old Linux years I always config Win computers the same. Admin account for installing software and so on, restricted user for every day use.
On my old XP's no problems at all. PSPad portable with all functions. The new computer has Win 7 x64. Copied my portable tools and used them without problems. On February 14th, 2012 this %$§&#.. update (IE8 --> IE9) was installed. Since this time the scripting is mixed up. Rolled back the update 2 days later, but no change in behaviour.
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-04 21:43 | IP: IP Logged
I do remember that the IE9 update resulted in two scripting engines being installed and PSPad showing duplicate entries in the script menu but I thought Jan fixed it internally somehow.
Tried a clean version of PSPad?
Carbonize
Posted by: Manfred62 | Date: 2013-04-05 10:17 | IP: IP Logged
carbonize:Tried a clean version of PSPad?
yes, I did. No change
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-05 18:01 | IP: IP Logged
OK so basically the problem is if you just run PSPad the script menu is there and populated but the scripts wont run?
Carbonize
Posted by: Manfred62 | Date: 2013-04-06 08:28 | IP: IP Logged
As restricted user the scripts in the dropdown are not present.
As admin all scripts are present and usable.
screenshots:
restricted
admin
BTW: thanks for your patience
PSPad 4.5.9 (2525)
Posted by: Manfred62 | Date: 2013-04-06 09:30 | IP: IP Logged
uups, sorry mixed up the links to screenshots.
admin is nonadmin, and nonadmin is admin
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2013-04-06 09:37 | IP: IP Logged
Restricted is normal and admin is when used as admin yes? If so I'm wondering if it's more an issue with not having access to that folder when not running as admin.
Carbonize
