You are here: PSPad forum > English discussion forum > Open file through script
Posted by: wimb | Date: 2012-12-05 10:41 | IP: IP Logged
I would like a script that opens a file in PSPad using an open dialog with a fixed path.
Can this be done with pspad scripting commands?
I've tried it with a JScript but I get an error:
try
var objShell, objDialog, appDataPath;
objShell = new CreateObject("WScript.Shell");
appDataPath = objShell.SpecialFolders("AppData");
objDialog = new CreateObject("UserAccounts.CommonDialog");
objDialog.InitialDir = appDataPath;
objDialog.Filter = "All files (*.*)|*.*;Log files (*.txt)|*.txt;Log files (*.log)|*.log";
if (objDialog.ShowOpen())
echo(objDialog.FileName);
else
echo("cancelled");
catch (err)
echo(err.message);
But this failes at the line
with the message "object doesn't support this property or method.
