You are here: PSPad forum > English discussion forum > Re: How to bring "Heart Tab" back?
Posted by: slono | Date: 2012-11-06 13:53 | IP: IP Logged
I moved it accidently and it is disappeared. How to bring it back?
Posted by: vbr | Date: 2012-11-06 23:05 | IP: IP Logged
slono:I moved it accidently and it is disappeared. How to bring it back?
usually, if you undock such item and close the separate tool-window, you can close PSPad and after the new start of the program this tool-window would appear again - you can then drag it back to the other tabs.
hth,
Posted by: slono | Date: 2012-11-09 14:31 | IP: IP Logged
yes, but it did not come back
Posted by: pspad | Date: 2012-11-09 17:20 | IP: IP Logged
If you undock it, it stays undocked.
Run PSPad settings / Direct edit button
In the left list select Panels
In the right list change value to LinkPanel=1
Confirm with OK Button and restart PSpad
