You are here: PSPad forum > English discussion forum > It is possible to make new explorer code file type ?
Posted by: Haric | Date: 2012-10-29 14:59 | IP: IP Logged
I use for my job a specific programming language. So I make a new user highlighter definition. I would like also
a new explorer code file type like ftCPP, ftCSHARP ... but how can I make it ? It is possible ?
Thanks in advance for your reply
Best regards
Posted by: pspad | Date: 2012-10-29 16:15 | IP: IP Logged
If your new language isn't similar to any existing, I can make it for you. Code explorer definitions are coded in program.
Posted by: Haric | Date: 2012-10-30 09:01 | IP: IP Logged
Thanks for your reply. In fact, it is similar to C language. I would especially like the function recognition.
This language is MTL (From AEROFLEX compagny). It is use in the industry to control testing system and make measurement on electronic components.
For example, with simple function
:addition(a int, b int) int
like in C
int addition(int a, int b)
or
:helloword() void
like in C
void helloworld(void)
If you want I can send you a program to see how it was written.
Thanks in advance
Best Regards
