You are here: PSPad forum > English discussion forum > problem - fast switching of all tabs before opening the file
Posted by: deeman | Date: 2012-10-11 06:13 | IP: IP Logged
Hi!
When I open text file through linked key (F4 in the Total Commander) PsPad quickly shows and hides all tabs (previously opened files) and after opens the needed file. How I can change this behaviour? When I open through the menu it's all right.
Thank you
Posted by: pspad | Date: 2012-10-11 16:26 | IP: IP Logged
PSPad version?
Posted by: deeman | Date: 2012-10-11 18:34 | IP: IP Logged
PsPad 4.5.6 (2427)
Posted by: pspad | Date: 2012-10-11 18:53 | IP: IP Logged
Download latest build from the developer forum
Posted by: deeman | Date: 2012-10-12 07:12 | IP: IP Logged
The same result
May be something wrong in the settings?
Posted by: prema_van_smuuf | Date: 2013-10-21 11:34 | IP: IP Logged
This is weird.
My PSPad (4.5.8 / 2457) suddenly started to do the same thing.
Quite annoying; if only I knew what's causing this..
