You are here: PSPad forum > English discussion forum > url escape characters; file name characters
#1 url escape characters; file name characters
Posted by: pspadder | Date: 06/23/2012 00:05 | IP: IP Logged
hi
does anyone know how to make all
be deleted or substituted with specified one(s) ?
also, how can one replace all chracters in a file that do not conform to the set that is used for file names ?
thanks in advance!
#2 Re: url escape characters; file name characters
Posted by: pspad | Date: 06/23/2012 07:00 | IP: IP Logged
For both your points you can use user convertors from the menu TOOLS.
E.g. chars to HTML safe form and back.
Convertor definition is simple text file. You can create new and when you will place it into subfolder .\convert, it automatically appears in Convertor list.
Open e.g. Safehtml.ini, copy it with another name and modify as you need.
