You are here: PSPad forum > English discussion forum > Re: compare 2 files with Text Diff
Posted by: djehres | Date: 06/11/2012 22:22 | IP: IP Logged
Is there a way to compare 2 files and have the difference written to a 3rd file?
Have 1 file open then:
Tools => Text Differences => Text Diff with this file...
and have the results written to a 3rd open file?
In the past I have to copy and paste out of the 2nd file to get the differences.
thanks.
Posted by: nergmlam | Date: 06/13/2012 08:39 | IP: IP Logged
Yes it's easy, but "kind of hidden".
Just after opening the second file, you get 5 ikons above them both.
Leftclick the last one to the right, called "Results processing", when you point your mouse over it, and then select "missing lines into new file".
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
