You are here: PSPad forum > English discussion forum > Re: MinGW highlighter settings
Posted by: Thistleknot | Date: 06/01/2012 19:42 | IP: IP Logged
First, I had to edit
pspad's
makefile.ini
add *.win to filetype
then to setup minigw...
I read this
gogogadgetscott.info
Why cmd.exe? Why do all the other instructions say gcc.
Also, the /C doesn't work for path...
then tried this
didn't work
then I read this
see x
bogdan-computer.x.com
x= b l o g s p o t (word is banned I guess)
and made my settings look like this
(I even had a path variable set to point to the \bin folder), I'd prefer a path variable set using the gcc options though.
compiler
F:\Dev-Cpp\MinGW64\bin\gcc.exe
param's
"%File%" -o "%Dir%%Name%.exe" -L"F:/Dev-Cpp/MinGW64/x86_64-w64-mingw32/lib" -I"F:/Dev-Cpp/MinGW64/x86_64-w64-mingw32/include" -I"F:/Dev-Cpp/MinGW64/x86_64-w64-mingw32/include" -L"-L"F:/Dev-Cpp/MinGW64/x86_64-w64-mingw32/lib" -I"F:/Dev-Cpp/MinGW64/"
default dir
F:\dev
logfile
%F:%L:*
run after
"%DIR%%NAME%.exe"
yet, I still keep getting "undefined reference to 'std::cout'" ...
Edited 9 time(s). Last edit at 06/01/2012 20:13 by Thistleknot.
Posted by: Thistleknot | Date: 06/01/2012 20:54 | IP: IP Logged
this fixed it
this got rid of a dll error (after going to 32 bit), but still getting cout errors
default dir:
F:\Dev-Cpp\MinGW32\bin
this fixed it
compiler:
F:\Dev-Cpp\MinGW32\bin\g++.exe
