You are here: PSPad forum > English discussion forum > Re: Select only text-string in code with shortcut
#1 Select only text-string in code with shortcut
Posted by: ledzep48 | Date: 05/25/2012 10:04 | IP: IP Logged
I select code and text with a standard shortcut: CRL + Shift + rightArrow.
But the selection does not stop when reaching a braket. F.e: "developer forum - new builds </ a>" -> The editor stops by the slash, not at the end of the word "builds".
Can I configure this?
thanx
Johann
Edited 1 time(s). Last edit at 05/25/2012 10:05 by ledzep48.
#2 Re: Select only text-string in code with shortcut
Posted by: myf | Date: 05/25/2012 12:00 | IP: IP Logged
There is no built-in configurable preference for it (afaik), but you may give a try to PSPad cursor enhancement extenstion. Not updated for some time, but functional.
#3 Re: Select only text-string in code with shortcut
Posted by: ledzep48 | Date: 06/04/2012 12:23 | IP: IP Logged
thanx for your hint!
