You are here: PSPad forum > English discussion forum > Re: Problem Saving Clip Definition files in Windows 7
#1 Problem Saving Clip Definition files in Windows 7
Posted by: kwarr | Date: 05/18/2012 15:54 | IP: IP Logged
Trying to save .DEF files in Win 7 gives the error "Error saving file "C:\Program Files (x86)\PSPad editor\Context\HTML.DEF"
I tried removing the 'Save only' settings for that folder and its contents but the error remained.
Running PSPad as administrator works OK but this is unsatisfactory
Is there a way to set an alternative location for the Context folder?
Win 7 Ultimate Service Pack 1
PSPad 4.5.6 (2427) - Multi User Environment
#2 Re: Problem Saving Clip Definition files in Windows 7
Posted by: pspad | Date: 05/18/2012 16:57 | IP: IP Logged
Not yet. I have to speed up work on it.
#3 Re: Problem Saving Clip Definition files in Windows 7
Posted by: kwarr | Date: 05/18/2012 19:37 | IP: IP Logged
Thank you - I look forward to it ...
Editor PSPad - freeware editor, © 2001 - 2015 Jan Fiala
