You are here: PSPad forum > English discussion forum > Connection does not exist
Posted by: pspad | Date: 2013-05-28 03:40 | IP: IP Logged
Read my first answer (3rd add) in this topic.
You don't understand your operating system behavior.
Simple advice: DON'T INSTALL PSPAD AS PORTABLE INTO PROGRAM FILES FOLDER
Posted by: Lytium | Date: 2013-10-04 16:25 | IP: IP Logged
1. I just uninstalled PSPad (I was using pspad on my old Dell laptop, but I really need to use it in this new one).
2. I verified "pspad editor" folder was empty after uninstalling.
3. I downloaded installer "pspad457inst_en".
4. I ran installer, ensuring "Portable application" option was UNCHECKED during setup.
5. I opened pspad, opened a connection to my server, but problem remains: I see not content at all. The square is green indicating im connected, but no contents are shown.
Posted by: Stefan | Date: 2013-10-04 17:43 | IP: IP Logged
Lytium:Hi,4. I ran installer, ensuring "Portable application" option was UNCHECKED during setup.
In which folder did you install PSPad?
Posted by: pspad | Date: 2013-10-04 17:55 | IP: IP Logged
If you are connected, but you don't see content of the folder, there can be problem with your "exotic" FTP server.
Go to FTP connection settings and set:
[x] Compatible mode
[x] Passive Mode
[ ] Show hidden files
Save and try reconect to your FTP server.
If no content will shown, connect, display FTP log window (Ctrl+L) and press LIST button in the Log window.
Paste content into new text file and send it as attachment to PSPad support mail.
