You are here: PSPad forum > English discussion forum > Date/filename in templates
#1 Date/filename in templates
Posted by: ruryop | Date: 05/12/2012 13:15 | IP: IP Logged
Hey,
Is it possible to include into template some kind of code, that when you use it, it'll write current date/filename into new file?
Cheers
#2 Re: Date/filename in templates
Posted by: alesc | Date: 05/14/2012 15:16 | IP: IP Logged
I don't think so but you could for sure script something like that.
1. Create your template using some syntax to identify
fields to modify.
e.g.
<date> <filename>
2. Write some script that opens that template, searches for the fields to modify and modifies it with current date and specified filename.
