You are here: PSPad forum > English discussion forum > Bad tab location
Posted by: oggologgo | Date: 05/11/2012 14:49 | IP: IP Logged
Just started using PSPad, and overall it seems very good, but I have a few requests.
- It would be much better, if the tabs were located directly above the document, instead of all the way to the left, above the tool panel. The tabs belong to the open documents, and should therefore be visually connected to them in that way.
- Similarly, the document close button should be located right above the document, and not all the way almost at the top of the program window.
- Scroll past EOF and EOL should be two sepearte settings. I want scroll past EOF enabled, but not past EOL.
- It would be nice with the option to move the tool panel to the right side.
Edited 1 time(s). Last edit at 05/11/2012 14:51 by oggologgo.
