You are here: PSPad forum > English discussion forum > SPELL CHECK NOT WORKING
Goto Page: 1 2 Next
#1 SPELL CHECK NOT WORKING
Posted by: garydavid711 | Date: 2012-05-09 11:24 | IP: IP Logged
Need to add dictionary so i can get spell check to work
anybody give me simple instructions-thanks
#2 Re: SPELL CHECK NOT WORKING
Posted by: pspad | Date: 2012-05-09 13:26 | IP: IP Logged
Did you read attached help?
Download and unpack dictionary(ies) into .\Spell subfolder
Run Spell settings (Ctrl+F7) from menu Settings in PSPad and choose dictionary
You can enable online spell check what will mark "bad" words or run Spell Check manually from menu Tools (F7)
#3 Re: SPELL CHECK NOT WORKING
Posted by: raviteja26187 | Date: 2013-02-16 02:35 | IP: IP Logged
I have installed dictionary and unpacked it but i am unable to check the spelling.[img][/img]
#4 Re: SPELL CHECK NOT WORKING
Posted by: pspad | Date: 2013-02-16 07:19 | IP: IP Logged
Press Ctrl+F7 or in menu settings / Spell settings choose your dictionary first.
#5 Re: SPELL CHECK NOT WORKING
Posted by: Noodle | Date: 2013-08-04 08:58 | IP: IP Logged
I've just installed PSPad and it looks to have everything that I need.
I thought that the spell-checker didn't work but a closer inspection of the downloaded dictionary shows that it contains many words not found in other English dictionaries, hence it is not picking up my spelling mistakes. For example if I mis-spell 'more' as 'mure' it is not picked up.
Is there another (English) dictionary that can be used instead? The main reason that I selected PSPad was to have a spell-checker in my HTML editor.
#6 Re: SPELL CHECK NOT WORKING
Posted by: pspad | Date: 2013-08-04 11:08 | IP: IP Logged
Press Ctrl+F7 (Spell Settings) and set English dictionary
PSPad spells text in HTML code only
#7 Re: SPELL CHECK NOT WORKING
Posted by: Noodle | Date: 2013-08-04 11:54 | IP: IP Logged
Thanks but that is what I did. The problem is the dictionary file doesn't reflect English spelling.
#8 Re: SPELL CHECK NOT WORKING
Posted by: pspad | Date: 2013-08-04 19:47 | IP: IP Logged
OK. You unpacked CAB file and English,.dic you put into Spell subfolder.
After it you choose dictionary in Spell settings
Only thing what can prevent spell check is active WordWrap mode. Can you switch it off please?
#9 Re: SPELL CHECK NOT WORKING
Posted by: smokemup | Date: 2013-08-11 01:52 | IP: IP Logged
Using PSPad v4.5.7 (2437). Downloaded the English spell check dictionary. Unpacked it. Placed the file English.2-1-0.dic in the \Spell subdirectory. Opened PSPad, went to spell settings, and the Dictionary selection windows is empty. No dictionaries to choose from.
#10 Re: SPELL CHECK NOT WORKING
Posted by: pspad | Date: 2013-08-17 12:06 | IP: IP Logged
Spell folder must be subfolder from the PSPad.exe location.
Ctrl+F7 should show you list of available languages
Goto Page: 1 2 Next
