You are here: PSPad forum > English discussion forum > Quotes+apostrophes syntax highlight bug
#1 Quotes+apostrophes syntax highlight bug
Posted by: Erigity | Date: 05/05/2012 08:46 | IP: IP Logged
Hi!
I'm using custom syntax highlight for BASIC-like language and face the problem after upgrading from 4.5.3(2272) to 4.5.6(2427).
Code example:
Quote:
SOMEVAR = "'highlighted like str'" : '"highlighted not like str"';
On 4.5.3 PSPad version, both strings highlighted as a strings, while on 4.5.6, the same syntax highlighter broke on
Quote:
part, highlighting
with code highlighting rules and then decides
Quote:
as a string too.
Thank you in advance.
#2 Re: Quotes+apostrophes syntax highlight bug
Posted by: Erigity | Date: 05/11/2012 08:14 | IP: IP Logged
Any suggestions?
#3 Re: Quotes+apostrophes syntax highlight bug
Posted by: Erigity | Date: 05/11/2012 08:28 | IP: IP Logged
It looks like, that ' inside of ", works fine, but if there's ' first, then " acts as another '.
So, the highlight is like:
L = "*'*'*" + '"*jji"' + '"A"' + "'sd'"; *comment
