You are here: PSPad forum > English discussion forum > Re: SQL (Oracle) Highlighting
Posted by: LucyFan | Date: 04/17/2012 14:11 | IP: IP Logged
Hi
From version 10g of Oracle it has been possible to specify alernate string identifiers...
A single inverted comma is no good if you have a single inverted comma in the string...
SELECT 'D'Arta' from dual
would cause a syntax error so you can now specify an additional identifier...
SELECT q'{D'Arta}' from dual
so in the above example q'{ starts the string and }' ends it...
It is possible to add this logic to the syntax highlighhter in PSPad, otherwise anything after the D' is no longer highlighted as text string.
Hope this makes sense
Thanks
Posted by: pspad | Date: 04/17/2012 19:09 | IP: IP Logged
I will do it.
Posted by: pspad | Date: 04/26/2012 12:44 | IP: IP Logged
Will be available in the next build
Posted by: LucyFan | Date: 04/30/2012 17:58 | IP: IP Logged
Thanks that would be great
Posted by: pspad | Date: 04/30/2012 20:09 | IP: IP Logged
Already available
Posted by: LucyFan | Date: 06/19/2012 19:16 | IP: IP Logged
Sorry for not responding sooner, thank you very much works well :0)
