You are here: PSPad forum > English discussion forum > PHP in JavaScript Multihighlighter
Posted by: calamity | Date: 03/30/2012 12:16 | IP: IP Logged
Hi guys,
PHP is not highlighted properly when used between <script> tags. It seems PSPad doesn't detect it is PHP.
Is that a bug, and if it is, is there a fix?
Best Regards,
Slavi
Posted by: carbonize | Date: 03/30/2012 12:34 | IP: IP Logged
Because PHP needs to be between <?php and ?> and is not a script a browser would recognise. The script tags are just used to tell the browser that the code there is something it can pas to it's scripting engine, usually JavaScript or VBScript.
Carbonize
Posted by: calamity | Date: 03/30/2012 12:56 | IP: IP Logged
Maybe an example will clarify things a bit.
<html>
<script>
var a = <?php echo $avalue; ?>;
</script>
</html>
It is not a big issue here, because it's only "echo $avalue", but larger portions of php code are not properly highlighted either.
Regards
Posted by: calamity | Date: 04/10/2012 09:49 | IP: IP Logged
The same problem appears when trying to put <?php ?> between <style></style> tags -- no php syntax highlighting.
Best regards,
me
Posted by: pspad | Date: 04/10/2012 19:49 | IP: IP Logged
There isn't and won't be multilevel highlighting
