You are here: PSPad forum > English discussion forum > Clear recent files list
Posted by: hamasaki | Date: 03/14/2012 11:24 | IP: IP Logged
Hi Jan,
Any chance you could move the 'Clear recent files list' option so its not next to the 'Remove noneexisting recent files' option?
As I regularly click the remove option I now find myself clicking the clear option by mistake and its removing everything.
Ideally an option to not show this menu item might be good?
Many thanks,
h
Edited 1 time(s). Last edit at 03/14/2012 11:28 by hamasaki.
Posted by: pspad | Date: 03/14/2012 11:40 | IP: IP Logged
Now you see the differences between users request.
One group of uses wants this option, second doesn't want it.
To create option for any menu item will cause coo complicated option dialog.
I will try to move it a little
Posted by: nergmlam | Date: 03/14/2012 15:28 | IP: IP Logged
Hi Jan
Quote:Any chance you could move the 'Clear recent files list' option so its not next to the 'Remove noneexisting recent files' option?
or maybe create shortcuts to those 2 functions (if any left)
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
Posted by: Ilya | Date: 03/15/2012 09:45 | IP: IP Logged
Or just add a separator between those lines
Posted by: pspad | Date: 03/15/2012 09:49 | IP: IP Logged
Ilya:Or just add a separator between those lines
This is exactly what I did. Wait for the next build.
Posted by: hamasaki | Date: 03/17/2012 13:27 | IP: IP Logged
pspad:Ilya:Or just add a separator between those linesThis is exactly what I did. Wait for the next build.
Thanks Jan, that should be fine.
