You are here: PSPad forum > English discussion forum > Crazy probléme with 2008R2 and PSpad
#1 Crazy probléme with 2008R2 and PSpad
Posted by: Arflam | Date: 03/10/2012 10:54 | IP: IP Logged
When i create a new file on C:\Windows\System32\WindowsPowerShell\v1.0 with NOTEpad
i can see it with:
notepad
powergui (Quest software)
dos command "dir"
powershell command "ls"
BUT
I cant see it... with
PSpad
notepad++
ConTEXT
The opposite is also true, i cant see with notepad (etc.), the files created by PSpad ! its is crazy !
its like pspad and notepad display the file system in a différent way of microsoft tools.
it is not a question of using or not "As administrator".
Can you do that ?
I use the las release.
#2 Re: Crazy probléme with 2008R2 and PSpad
Posted by: pspad | Date: 03/10/2012 11:39 | IP: IP Logged
Read something about windows folder virtualization
www.symantec.com
Edited 1 time(s). Last edit at 03/10/2012 11:42 by pspad.
#3 Re: Crazy probléme with 2008R2 and PSpad
Posted by: Arflam | Date: 03/10/2012 13:51 | IP: IP Logged
Ok, i understand Folder Virtualization, but how can i give to pspad the same way of working than notepad or powergui ?
For me, it change nothing if i lauch pspad as administrator. This is why i don't understand, it is not like in your article. Il still dont see the files created befor and REALLY in the real directory.
Edited 1 time(s). Last edit at 03/10/2012 13:55 by Arflam.
#4 Re: Crazy probléme with 2008R2 and PSpad
Posted by: pspad | Date: 03/10/2012 13:59 | IP: IP Logged
Don't create any files in Program files or Windows folder.
I don't see any reason why to do it.
You try to look into 64 bit's folder with 32 bits programs (PSPad, Contex, ...)
Inside program you will see that you are in \Windows\System32, but in the real you are in \Windows\SysWOW64
Use ny 64 bits editor and you will see the content same as with Notepad.
#5 Re: Crazy probléme with 2008R2 and PSpad
Posted by: Arflam | Date: 03/10/2012 17:42 | IP: IP Logged
I see at least 3 in my case
Microsoft.PowerShell_profile.ps1
Microsoft.PowerShellISE_profile.ps1
powershell.exe.config
Thank you very much for your answers.
I hope you will be able toport pspad to 64bit.
