You are here: PSPad forum > English discussion forum > Bug: shortcut turns on "Whole Words Only"
#1 Bug: shortcut turns on "Whole Words Only"
Posted by: DG | Date: 12/08/2011 21:13 | IP: IP Logged
In version 4.5.7 (2433)
1. Search for a string, using the Ctl-F dialog. Verify that option "Whole Words Only" is not checked.
2. Click Ok to find.
3. Use Ctl-Shift-UpArrow/DownArrow to find previous or find next.
4. Do Ctl-F again to open the find dialog. Option "Whole Words Only" is now enabled.
This bug causes subsequent searches for partial strings to fail.
Regards,
DG
#2 Re: Bug: shortcut turns on "Whole Words Only"
Posted by: pspad | Date: 12/14/2011 21:38 | IP: IP Logged
Can't confirm
#3 Re: Bug: shortcut turns on "Whole Words Only"
Posted by: Blues48 | Date: 12/14/2011 22:00 | IP: IP Logged
Cannot confirm this, either.
Works fine here as it should, both on Vista32 and WinXP
