You are here: PSPad forum > English discussion forum > Re: Files do not open
Goto Page: Previous1 2 3 4
#31 Re: Files do not open
Posted by: jojojr | Date: 06/15/2012 14:48 | IP: IP Logged
Thank you Sektor,
your patch works fine for me (Win 7, 64bits)
Great jobsmiling smiley
#32 Re: Files do not open
Posted by: Jekyll | Date: 09/03/2012 13:47 | IP: IP Logged
I had the same problem - and found a solution! smoking smiley
So for everyone like me who doesn't like to run dubious exe-files posted in the forum (which is down anyway), change the registry setting yourself like this:
HKEY_CLASSES_ROOT --> Applications --> PSPad.exe --> shell --> open --> Command
add "%1" to the end of the path:
Type: REG_SZ
Value: "C:\Program Files\PSPad\PSPad.exe" "%1"
Edited 2 time(s). Last edit at 09/03/2012 13:52 by Jekyll.
#33 Re: Files do not open
Posted by: Mugros | Date: 11/05/2012 21:49 | IP: IP Logged
Had the same problem now in Windows 8. Just running PSPADShell_unreg.bat actually fixed the problem that it won't open the file.
#34 Re: Files do not open
Posted by: peter65 | Date: 04/30/2013 15:15 | IP: IP Logged
Hi!
Is the patch-source still available? I got a very new Windows Server 8 64bit. Double click to a file does not open it! What was the solution of PSPad_patch? Why is it a secret???? Where can I download the source?
THX, Peter.
#35 Re: Files do not open
Posted by: peter65 | Date: 04/30/2013 15:37 | IP: IP Logged
Hi!
I got it. It was only to .cfg-files. I used Program settings / System to register filetype .cfg. Now it works.
Sorry, Peter
#36 Re: Files do not open
Posted by: pspad | Date: 04/30/2013 16:28 | IP: IP Logged
What are you talking about? There is no secret patch. Do you use the latest PSPad version?
Check the registry, as is mentioned here or run PSPad as administrator, in the program settings / System integration uncheck all integration, confirm and check back.
#37 Re: Files do not open
Posted by: pspad | Date: 04/30/2013 16:29 | IP: IP Logged
Sorry, I answered your first add winking smiley
