You are here: PSPad forum > English discussion forum > Keyboard Shortcut
Keyboard Shortcut
#1 Keyboard Shortcut
Posted by: Blues48 | Date: 12/05/2011 19:30 | IP: IP Logged
I've been trying to match some shortcuts to my other software:
1) Ctrl Shift Del = to delete til END of Line.
I was not able to enter this. No Del or Backspace combination is accepted. So I did a direct edit. That worked after a re-start.
BTW, the Search dialog in the direct edit does not work.
2) Where do I find the option to delete to the left, to STart of Line? Is there a way to do this? I was planning to assign Ctrl Shift Backspace to it, but cannot find the command "Delete to Start of Line"
Other than that, I am very impressed with this software. Thanks for this great program.
#2 Re: Keyboard Shortcut
Posted by: pspad | Date: 12/14/2011 21:05 | IP: IP Logged
1. command ecDeleteEOL (in keymap editor as DeleteEOL), standard shortcut Shift+Ctrl+Y
2. command ecDeleteBOL was missed in keymap editor. I will include it in the next biuld
#3 Re: Keyboard Shortcut
Posted by: Blues48 | Date: 12/14/2011 21:56 | IP: IP Logged
Thank you, much appreciated.
I already tried this: Added the following line to the keymap.ini:
ecDeleteBOL=Ctrl Shift "some letter"
I figured BOL was the equivalent to EOL, but it didn't work.
#4 Re: Keyboard Shortcut
Posted by: pspad | Date: 12/14/2011 22:11 | IP: IP Logged
Blues48:
Add commant into INI isn't enough. There is neccessary program change. Be patient please, it will be included in the next developer build
Editor PSPad - freeware editor, © 2001 - 2015 Jan Fiala
