You are here: PSPad forum > English discussion forum > User highlighters : Adding comment characters
Posted by: dartiss | Date: 09/27/2011 17:35 | IP: IP Logged
I'm attempting to create my own highlighter for IBM 4680 Basic.
It has a number of different ways of identifying comments, such as the explanation mark and the command REM. All of these I can identify with my own highlighter.
However, the back slash character is also used. It's actually used to split code across multiple lines but, as all code afterwards is ignored, it's also used for comments.
Is there a way for me to add this in?
David.
Posted by: pspad | Date: 09/27/2011 19:17 | IP: IP Logged
User highlighter doesn't support splitting lines.
I can add back slash char as comment to PSpad, but you need to describe me rules for this comment style
Posted by: myf | Date: 09/27/2011 20:06 | IP: IP Logged
apropos, backslash "negating" EOL has this meanig in several (mostly C-like) languages:
I am sure about Javascript – in string literals
var str = "a\
b\
c"
is the same as
var str = "abc"
I suppose in C/C++ it is alike, but moreover I recently red quite amusing article ( www.elpauer.org ) describing fact that in C even comment could look like
// comment\
also comment
I know it's quite marginal case and difficulties implementing it in highlighter engine would probably not be be worth it, but no doubt having highlighter that truly reflects syntaxes with all peculiarities would be neat :]
