You are here: PSPad forum > English discussion forum > Problem with formatting (tab, spaces)
#1 Problem with formatting (tab, spaces)
Posted by: lukasamd | Date: 09/26/2011 00:24 | IP: IP Logged
I use PSPadas quick and very light editor. I also use Netbeans, and there is a problem with formatting in PSPad - when I open file in Netbeans, code formatting is "crashing"...
I use default editor options, what can do to make PSPad formatting the same as Netbeans/Eclipse/other IDE standard?
#2 Re: Problem with formatting (tab, spaces)
Posted by: vbr | Date: 09/26/2011 16:51 | IP: IP Logged
lukasamd:
in most cases, PSPad just behave in a standard way;
it is not quite clear, what are the problematic aspects for the file interchange PSPad-Netbeans, you experience, but, as a wild guess, you may check e.g. the following options:
Settings: Editor (part 1): Trim trailing spaces
Settings: Editor (part 2): Real tabs
Settings: Editor (part 2): Smart tabs
Settings: Editor (part 2): Tab width
Settings: Files and Dirs: New file format: (DOS/UNIX/MAC)
Possibly also the encoding: shown in statusbar, settable via menu: Format.
hth,
