You are here: PSPad forum > English discussion forum > files comparing / ansys syntax
#1 files comparing / ansys syntax
Posted by: berkaninhesabi | Date: 08/05/2011 11:34 | IP: IP Logged
Dear friends,
I am a new pspad user and i would like to ask you two questions.
1) When I open a file with PSPAD, all the time, I have to change the syntax to ANSYS. I am just wondering if I can make it somehow default so that whenever I open a file, ansys syntax is already selected?
2) I have two files and I want to compare and see the differences between the lines. Like is there an option where all the lines are compared and the differences are showed?
I would really appreciate your help.
Peace
berkan
#2 Re: files comparing / ansys syntax
Posted by: pspad | Date: 08/05/2011 13:53 | IP: IP Logged
1. PSpad recognize highlighter via file extension. What highlighter is used when you open file? Is your file extension in Highlighter extension list (menu settings / Highlighter)
Second problem can be, if your file is too big. There is set limit for using highlighter.
Go to program settings / Direct edit button and increase value of variable (in bytes) HlUpToSize=xxxxxxx
2. the line difference is shown on the bottom of PSpad window. I suggest you dowload the last build from PSPad developer forum
