You are here: PSPad forum > English discussion forum > PSPad-menus and Intel(R) HD Graphics-Card
#1 PSPad-menus and Intel(R) HD Graphics-Card
Posted by: padfox | Date: 07/08/2011 20:23 | IP: IP Logged
just configuring my new notebook, which uses an Intel(R) HD Graphics-Card. OS Win 7/64Bit. When I open an PSPad-project with >100 open files/tabs opening and showing one of the menus lasts up to 10s. Can someone test/confirm that?
Many thanks and greetings
padfox
#2 Re: PSPad-menus and Intel(R) HD Graphics-Card
Posted by: pspad | Date: 07/09/2011 17:50 | IP: IP Logged
What PSpad version do you use?
Did you try the current 4.5.5 build from PSPad developer forum?
#3 Re: PSPad-menus and Intel(R) HD Graphics-Card
Posted by: padfox | Date: 07/10/2011 00:16 | IP: IP Logged
Hello Jan,
thanks for your reply. After installing the new version, I found the reason, not PSPad-related.
But what is the difference between 4.5.4 (2356) which I used and the new 4.5.5 (2417) in the context of my mentioned problem?
Greetings
padfox
Edited 1 time(s). Last edit at 07/10/2011 00:44 by padfox.
#4 Re: PSPad-menus and Intel(R) HD Graphics-Card
Posted by: pspad | Date: 07/10/2011 08:13 | IP: IP Logged
There is rewrited draw method and fixed problem with redraw button. Each file opening redraw it all and if you want to open 100 files, it takes a long time and flashing.
