You are here: PSPad forum > English discussion forum > Integration with TopStyle
#1 Integration with TopStyle
Posted by: pimenta | Date: 07/05/2011 09:36 | IP: IP Logged
Before work with PSPad I used Homesite (all versions).
With Homesite I integrate all de versions de TopStyle.
When I changed Homesite by PSPad I worked with Homesite+ and TopStyle Pro 3.5.0.9
Now, with PSPad I don't get the integration.
It is a limitation of PSPad?
I search the integration in the PSPad files, in the Registry and I didn't found how to do.
I read in the Forum that it is impossible! I don't believe.
#2 Re: Integration with TopStyle
Posted by: carbonize | Date: 07/05/2011 10:25 | IP: IP Logged
PSPad integrates with Topstyle lite and not the full version.
Carbonize
#3 Re: Integration with TopStyle
Posted by: pspad | Date: 07/05/2011 10:29 | IP: IP Logged
The full version doesn't offer possibility to be integrated by other application
#4 Re: Integration with TopStyle
Posted by: pimenta | Date: 07/05/2011 21:48 | IP: IP Logged
It worked integrated with Homesite+.
So, the problem is in PSPad, not in TopStyle Pro 3.
#5 Re: Integration with TopStyle
Posted by: pspad | Date: 07/06/2011 09:00 | IP: IP Logged
Did you read this?
forum.pspad.com
#6 Re: Integration with TopStyle
Posted by: pimenta | Date: 07/07/2011 21:36 | IP: IP Logged
Thanks
