You are here: PSPad forum > English discussion forum > Selection Bug Pls. Help
Posted by: jean123456 | Date: 05/06/2011 19:29 | IP: IP Logged
This bug was reported in
forum.pspad.com
but I could not reply to it.
For me, this is what is happening:
I can only select part but not all of what I want. On some lines, I can only select 6 characters.
On other lines, I can select most of the line but not all of it.
When I try to change something, the characters are added in the wrong place.
Sometimes when I highlight something, random blanks are added to the text while it is selected that then disappear when the selection is gone.
I tried turning scroll past EOL & EOF off and on (It was already on for me) and this had no effect.
The bug seems to have appeared since I changed my background colours in the highlighter settings.
I thought I could fix it with uninstall/reinstall but because it kept all my settings, this did not work!! I even tried uninstalling, running a registry cleaner and then reinstalling and this didn't work either.
jean
PS
ETA
My two uninstall/reinstall attempts to fix that did not work.
Edited 2 time(s). Last edit at 05/06/2011 19:36 by jean123456.
Posted by: pspad | Date: 05/06/2011 21:13 | IP: IP Logged
I am not able repair anything if I am not able to simulate it
