You are here: PSPad forum > English discussion forum > Search/Replace in Files sometimes doesn't work anymore
#1 Search/Replace in Files sometimes doesn't work anymore
Posted by: padfox | Date: 03/28/2011 17:47 | IP: IP Logged
sometimes I have the problem that Search/Replace in Files doesn't work anymore. That happens suddenly. Even closing all instances doesn't work. After some time it worked again. I'm searching in all files of the Project.
Any hints? Are there any settings stored somewhere?
Many thanks and greetings
padfox
#2 Re: Search/Replace in Files sometimes doesn't work anymore
Posted by: padfox | Date: 06/22/2011 22:54 | IP: IP Logged
Hello again,
during the last months I have had that problem many times. It's really nasty. Is there any way to find a solution?
Greetings
padfox
#3 Re: Search/Replace in Files sometimes doesn't work anymore
Posted by: pspad | Date: 06/23/2011 10:37 | IP: IP Logged
If you write "sometimes", it really doesn't help me.
I need situation, where it doesn't work.
The often problem is bad extension settings
