You are here: PSPad forum > English discussion forum > Re: BUG: Smart tab switching doesn't work after opening page preview (F10)
Posted by: padfox | Date: 2011-03-21 12:26 | IP: IP Logged
Hello hankejh,
same problem here. I have ~100 files open, I select files
A, B, C via mouse (click on Tab), C active:
Ctrl+Tab: C->B->A
Ctrl+Shift+Tab: doesn't work, normal selection
Selecting files via a script doesn't work in any way.
Greeings
padfox
Edited 1 time(s). Last edit at 2011-03-21 12:27 by padfox.
Posted by: padfox | Date: 2011-06-22 20:55 | IP: IP Logged
Hello again,
still no solution?
Greetings
padfox
Posted by: padfox | Date: 2012-02-10 09:30 | IP: IP Logged
Hello again,
yep, any news?
Many thanks and greetings
padFox
Posted by: Get Free | Date: 2012-07-03 08:30 | IP: IP Logged
I'm afraid this old problem is still not fixed, not even in v4.5.6.
Can anyone confirm if there is a beta release or development release where we can see the smart tab switching working properly?
Posted by: carbonize | Date: 2012-07-03 12:24 | IP: IP Logged
Seems that the internal preview is causing problems all round then as it's also responsible for this bug - forum.pspad.com
Carbonize
Posted by: Get Free | Date: 2012-10-29 14:32 | IP: IP Logged
This bug has been present for so long and is so anoying.
Is there any change of it being fixed soon?
You can reproduce the bug very easily:
1. Set the tab switching option to "last two files"
2. Open several files so you have more than one tab open
3. Press F10 to open the "HTML page preview" window
4. Close the "html page preview" window
5. Press Ctrl+Tab repeatedly to switch between tabs
The result in step 5 is that tabs switch in a chaotic order.
