You are here: PSPad forum > English discussion forum > Cygwin as C++ Compiler
#1 Cygwin as C++ Compiler
Posted by: DilanShah | Date: 02/21/2011 18:02 | IP: IP Logged
I am using Cygwin on Windows 7 with PSPad and am trying to set up the compiler in highlighter settings to compile an executable of C++ code.
I have followed an example way of doing this, but I cannot get it to compile, even though I have set up the paths correctly.
When I use
/C "set PATH=%PATH%;C:\cygwin\bin\; & make"
I get the message:
make: *** No targets specified and no makefile found. Stop.
Process completed, Exit Code 2.
Execution time: 00:00.136
I then changed the parameters to
/C "set PATH=%PATH%;C:\cygwin\bin\; & g++"
and then I just get the message:
Access is denied.
Process completed, Exit Code 1.
Execution time: 00:00.036
Can anyone help me with this?
Thanks.
