You are here: PSPad forum > English discussion forum > Re: How to mark/unmark some lines as comments
Posted by: vadim.zenin | Date: 2010-09-28 11:46 | IP: IP Logged
Thanks for nice editor.
How to mark/unmark block of lines as comments?
Thanks,
Vadim
Posted by: MrSpock | Date: 2010-09-28 14:07 | IP: IP Logged
See the Format menu. I think the default keyboard shortcut is Ctrl+Shift+A.
Posted by: vbr | Date: 2010-09-28 14:07 | IP: IP Logged
vadim.zenin:Hi,
Thanks,
Vadim
Hi, for languages with line comments, use Ctrl+Shift+A (menu Format: Comment/Uncomment).
For other languages, like HTML, you can use the clips for that:
Ctrl+Space - select "line comment" or "block comment" (at the very beginning of the list) to insert
<!-- ... --> around the selected block.
hth,
Posted by: barstowman | Date: 2013-09-18 19:31 | IP: IP Logged
In an XML file, how do you uncomment a selection using ctrl-space.
