You are here: PSPad forum > English discussion forum > FTP problem in Windows 7 64-bit
#1 FTP problem in Windows 7 64-bit
Posted by: javadecaf | Date: 08/04/2010 22:12 | IP: IP Logged
One of the things I really love about PSPad is the integrated FTP support; unfortunately, it doesn't seem to work under Windows 7 sad smiley. When I create a new connection, save it, then try to connect, it says "Connection doesn't exist." When I click "edit" the fields I just entered are blank. Also, I tried to import an XML file from FileZilla and got nothing. Is this is a known issue and is there anything that can be done to fix it?
Edited 2 time(s). Last edit at 08/04/2010 22:13 by javadecaf.
#2 Re: FTP problem in Windows 7 64-bit
Posted by: pspad | Date: 08/05/2010 06:16 | IP: IP Logged
You install PSPad not as multiuser environment.
In this case all settings is stored into PSpad folder. No application except installer has rights to write into Program files folder.
In program settings / System check [x]Multiuser environment. This will store PSpad config files in your profile folder.
#3 Re: FTP problem in Windows 7 64-bit
Posted by: joehopkins | Date: 12/06/2011 12:38 | IP: IP Logged
That didn't work for me - I get exactly the same error? sad smiley
#4 Re: FTP problem in Windows 7 64-bit
Posted by: pspad | Date: 12/06/2011 13:25 | IP: IP Logged
You have to run PSpad as administrator (use right mouse - run as administrator) to change this setting
#5 Re: FTP problem in Windows 7 64-bit
Posted by: joehopkins | Date: 12/12/2011 13:56 | IP: IP Logged
You legend! It works.
Thanks ever so much.
Joe
