You are here: PSPad forum > English discussion forum > Updated html, xhtml, css def
Posted by: carbonize | Date: 10/23/2010 20:08 | IP: IP Logged
Yes I think we do as IE9 is in beta and supports a lot of the commonly supported HTML 5 tags as well as some CSS 3. Video and audio are the two main ones along with the new input attributes I mentioned. Then HTML 5 supports just using <!DOCTYPE html> so that will need adding to the list along with the fact HTML 5 only requires <script> and <style> without the type attribute as it will treat anything in these tags as JavaScript and CSS respectively unless the type attribute is present and says otherwise.
Then we have the CSS3 stuff but the issue with a lot of it is WebKit and Mozilla insisting on using prefixs for them in the form of -webkit- and -moz- which makes life difficult all round. But yeah we need to add border-radius and support for css transitions etc.
Carbonize
Posted by: Manfred62 | Date: 10/26/2010 18:13 | IP: IP Logged
Only a small update in css.def, added 2 shortcuts:
- Ctrl+Alt+B --> open new brackets {}
- Ctrl+Alt+C --> set a comment
regards Manfred
PSPad 4.5.8 (2455)
Posted by: Manfred62 | Date: 10/26/2010 21:39 | IP: IP Logged
Next small fix in xhtml.def:
- insert internal java script misses backslashes
//<![CDATA[
regards Manfred
PSPad 4.5.8 (2455)
Posted by: carbonize | Date: 11/07/2010 23:28 | IP: IP Logged
Maybe you could integrate some of the changes from these HTML5 files - www.pspad.com
Carbonize
Posted by: Manfred62 | Date: 11/12/2010 14:06 | IP: IP Logged
carbonize:Maybe you could integrate some of the changes from these HTML5 files - www.pspad.com
What changes do you mean espacially? Tags, syntax..?
regards Manfred
PSPad 4.5.8 (2455)
Posted by: carbonize | Date: 11/12/2010 14:12 | IP: IP Logged
well since we can't change the syntax highlighting without creating our own I mainly mean some of the HTML 5 tags such as audio, video and their attributes as well as the new attributes for inputs such as required, pattern and the different types. Be nice if you could also add some of the more exotic CSS3 stuff such as border-radius but wondering if there isn't a way to make it do all the varying border-radius methods from a single input (-moz-border-radius, -webkit-border-radius etc)
Carbonize
Posted by: Manfred62 | Date: 11/12/2010 16:13 | IP: IP Logged
html 5: hmm, that's not so nice. Think, it's better to use the real (full) html 5 def. If starting to mix (x)html with html5 tags, you don't get clean (valid) code.
Just now you can use the (more simple) html5 doctype with (x)html.
Thats no problem with browsers and validation.
It sets all browsers in standard mode (like strict).
css3: I already have a first draft for a full css3 def.
But no time to make it ready to go
Like you mentioned, there are some already now and then used properties,
that we could include in the actual css.def
Will take a look into it...
A nice idea would be -->
you choose border-radius,
then you get the popup for attributes -->
and with checkboxes for the prefixes -->
make your selection, enter -->
-webkit-border-radius: 60px;
-moz-border-radius: 60px;
Not sure, how to realize this. But I try it.
regards Manfred
PSPad 4.5.8 (2455)
Posted by: carbonize | Date: 11/12/2010 17:02 | IP: IP Logged
Yeah I don't understand why the browser vendors have done things that way, either you support the feature or not.
Carbonize
Posted by: Manfred62 | Date: 12/06/2010 18:39 | IP: IP Logged
Small update in both html files. Completed favicon link with missingtype="image/x-icon"
www.box.net
Manfred
PSPad 4.5.8 (2455)
Posted by: Manfred62 | Date: 06/23/2011 22:07 | IP: IP Logged
Small update for the css file.
Now included option for class, id and selector,
type . --> class --> type name or choose a option
type # --> id --> type name or choose a option
selector --> type name or choose option
options for class and id are:
wrapper;header;navigation;content;sidebar;footer
configure your most needed options/names in line 27/43
options for selector are:
html;body;h1;h2;h3;h4;h5;h6
configure your most needed selectors in line 64
also included the browser prefix
-moz-,-webkit-,-o-,
Same link: www.box.net
regards Manfred
PSPad 4.5.8 (2455)
Edited 1 time(s). Last edit at 06/23/2011 22:07 by Manfred62.
