You are here: PSPad forum > English discussion forum > Updated html, xhtml, css def
Posted by: Manfred62 | Date: 2010-09-18 17:01 | IP: IP Logged
Next small update:
Conditional comments --> added IE 9
Cleaned up --> all tags with 1 are with attributes
(ex. strong1, em1, br1...)
Added class and id in css.def. Now you can later add class or id to every tag.
BTW: my favourite doctype is xhtml. Maybe the html file could be done better..?
regards Manfred
Posted by: Manfred62 | Date: 2010-09-23 18:08 | IP: IP Logged
Small update:
added in css.def:
border: none;
EDIT: above I wrote
Quote:Added class and id in css.def.
Should be ... in html/xhtml.def
regards Manfred
Edited 1 time(s). Last edit at 2010-09-23 18:11 by Manfred62.
Posted by: Manfred62 | Date: 2010-09-24 12:31 | IP: IP Logged
Next small update:
in css.def added shortcut to
margin: 0;
margin: 0 auto;
padding: 0;
regards Manfred
Posted by: Manfred62 | Date: 2010-09-24 16:58 | IP: IP Logged
Sorry for inconvience
changed the behavior from margin 0
Now you get this already filled in:
margin: 0 auto;
so it's easier to change it to 0
files are updated at www.box.net
regards Manfred
Posted by: Manfred62 | Date: 2010-09-26 09:22 | IP: IP Logged
Short tip for better html/xhtml workflow:
in the defs of html/xhtml you can include your most used class and id names. Example:
%id%=@C id=,id=,,[];wrapper;header;navi;navigation;content;footer,"
This you can edit yourself at "Settings/Edit Clip Definition File" --> html and/or xhtml.
regards Manfred
Posted by: Manfred62 | Date: 2010-10-21 19:59 | IP: IP Logged
Next update:
cleaned up the html.def, small corrections in xhtml.def.
Same identifiers in both html and xhtml file, same shortcuts.
Added html5 doctype to html.def:
<!doctype html>
Its possible (without browser problems) to use the new doctype with classic "html 4.01 strict" tags.
regards Manfred
Posted by: Manfred62 | Date: 2010-10-22 16:43 | IP: IP Logged
Next update: now I also included html 5 doctype and page template to xhtml.def
Use of the new doctype with classic html or xhtml tags is much easier, and all browser recognize it.
Tested both --> validator says ok.
regards Manfred
PSPad 4.5.9 (2525)
Posted by: carbonize | Date: 2010-10-23 06:59 | IP: IP Logged
Have you added support for things like <video> and <audio> yet? Along with the new input types of date, number, email as well as the other attributes like placeholder and required?
Carbonize
Posted by: Manfred62 | Date: 2010-10-23 13:29 | IP: IP Logged
carbonize:Have you added support for things like <video> and <audio> yet? Along with the new input types of date, number, email as well as the other attributes like placeholder and required?
You mean full html 5? No, the files are only with classic html and xhtml tags.
If you are looking for complete html 5:
www.pspad.com
I tried these, but couldn't get the highlighter active
Maybe, we should open a new thread for html 5?
regards Manfred
PSPad 4.5.9 (2525)
Edited 1 time(s). Last edit at 2010-10-23 13:29 by Manfred62.
Posted by: Manfred62 | Date: 2010-10-23 14:04 | IP: IP Logged
Next short update for both html and xhtml.
The HTML 5 template now with language selection:
<!DOCTYPE html>
<html lang="xx">
<head>
<meta charset="utf-8">
<title>
www.box.net
regards Manfred
PSPad 4.5.9 (2525)
