You are here: PSPad forum > English discussion forum > Support for JScript active scripting not found
Goto Page: 1 2 3 Next
#1 Support for JScript active scripting not found
Posted by: hibou57 | Date: 01/02/2009 11:05 | IP: IP Logged
From PSPad, I got the following error message box :
> Support for "JScript" active scripting not found !
> Install WSH with requested language support.
This error message box pops up at PSPad startup.
WSH is installed with JScript support (JScript is native of WSH, as well as VBScript).
Running a JScript file from this Windows cession works fine (so there is no trouble with WSH installation).
This only occurs for one of the three accounts of my computer (PSPad works fine with the two other ones).
How does PSPad get access to WSH ? I would like to have track to be able to guess where the problem is.
Many thanks if one have an idea, otherwise, I would try to do the best I can alone.
Any way, have a nice new year smiling smiley
Edited 3 time(s). Last edit at 01/02/2009 11:07 by hibou57.
#2 Re: Support for JScript active scripting not found
Posted by: pspad | Date: 01/02/2009 16:32 | IP: IP Logged
PSPad uses WSH as COM server from system.
#3 Re: Support for JScript active scripting not found
Posted by: hibou57 | Date: 01/03/2009 00:02 | IP: IP Logged
Thanks for the answer smiling smiley
I do not know how COM server works (just heard about what COM is, no more).
So you think this is a COM trouble ?
Do you know where I should look in to solve this ? Is it in the registry ? Is there something in the Windows system configuration panel which deal with this ?
Thanks again for the track about COM tongue sticking out smiley
Yannick
#4 Re: Support for JScript active scripting not found
Posted by: hibou57 | Date: 01/05/2009 04:53 | IP: IP Logged
Is it OLE Automation ?
#5 Re: Support for JScript active scripting not found
Posted by: phunkydizco | Date: 01/28/2009 15:26 | IP: IP Logged
hibou57:
I have the same problem after updating to 4.5.4 (2335) English. Please help!
#6 Re: Support for JScript active scripting not found
Posted by: clanman | Date: 02/02/2009 05:43 | IP: IP Logged
If this is only happening on one out of a number of accounts on the same machine, it sounds as though there are some rights differences between the accounts or perhaps a corrupt hive.
#7 Re: Support for JScript active scripting not found
Posted by: Lolo Irie | Date: 03/20/2009 10:54 | IP: IP Logged
I had the same issue since IE8.
Just updating WHS on my machine solves that.
www.microsoft.com
Good luck
Lolo
#8 Re: Support for JScript active scripting not found
Posted by: misterjp | Date: 03/25/2009 09:19 | IP: IP Logged
I had the same problem since IE8. Installing again WSH solve the problem with pspad, but IE8 is now really buggy and crash every minute.
I installed again IE8, and the problem with PSPad and JScript came back.
Any other solution ?
JP.
#9 Re: Support for JScript active scripting not found
Posted by: pspad | Date: 03/25/2009 16:36 | IP: IP Logged
Windows XP SP3, PSpad, WSH, IE8 without problem.
#10 Re: Support for JScript active scripting not found (solved)
Posted by: misterjp | Date: 03/31/2009 16:15 | IP: IP Logged
Using processmonitor helped me track this problem : I had a script file in the "Program Files\PSPad editor\Script\JScript" folder which did not have the module_name and module_ver variables declared.
Adding these variables solved my problem
On my computer, the problem can easily be reproducted by creating an empty js file in the "Program Files\PSPad editor\Script\JScript" folder.
Regards,
JP.
