You are here: PSPad forum > English discussion forum > Re: Resize images keeping aspect ratio
Posted by: Eyael | Date: 2008-01-28 17:26 | IP: IP Logged
I was wondering whether there was a way to (like an extension) to resize images keeping the aspect ratio with PSPad. An example to illustrate what I mean :
Let's say I have an image I want to include in a HTML page with reduced size and a link so that if the viewer click on it the image will display in its original size and I want to use just one image for that.
My original picture's dimensions would be height="250" and width="450"
Well, I'd like to have the width reduced to 300, so I would like something to calculate what the new height should be so that the aspect ratio is respected (so that the image is not deformed). I usually use Kompozer or an external image editor to that, but it's a bit tricky when I have many pages with images so I would appreciate a solution using only PSPad.
Posted by: pspad | Date: 2008-01-28 19:05 | IP: IP Logged
PSpad isn't graphic editor. It doesn't contains picture manipulation functions.
Posted by: MrSpock | Date: 2008-01-28 19:27 | IP: IP Logged
Eyael, I guess what you mean is not changing the actual size of the image, but only the display size, like:
<img width="100" height="200" ...>
becomes<img width="50" height="100" ...>
. Right?
This wasn't exactly your question, but why don't you try using only one of the attributes? AFAIK, all browsers will scale the image correctly if you only give width or height.
Posted by: Eyael | Date: 2008-01-28 19:52 | IP: IP Logged
Yes, I did mean changing the display size, sorry!
I didn't know that if you only put one of the dimension, the browser will put the other right. Thanks for the tip, I shall give it a try!
Posted by: Eyael | Date: 2008-01-29 17:49 | IP: IP Logged
Just to let you know I've tried your tip and it worked perfectly so I guess that will be it. Thanks a lot!
Posted by: MrSpock | Date: 2008-01-29 23:03 | IP: IP Logged
Ah, excellent.
Posted by: lily | Date: 2014-03-07 02:30 | IP: IP Logged
pspad:PSpad isn't graphic editor. It doesn't contains picture manipulation functions.
so you mean we need a graphic editor to resize image size. and what image editor will be suitable at this situation . because we want to keep the ratio the same. thank you in advance.
Edited 1 time(s). Last edit at 2014-03-07 02:30 by lily.
Posted by: carbonize | Date: 2014-03-07 09:00 | IP: IP Logged
Resizing images by HTML is bad practice. They tend to look terrible and can be a waste of bandwidth. Always resize an image to the desired size using an image editor.
As to your choices any fully fledged editor such as GIMP, Paint.NET, Paintshop Pro etc will do it or most image viewers such as Irfanview or XNView have the ability to resize and all will have the option to maintain aspect ratio.
Carbonize
