You are here: PSPad forum > English discussion forum > PSPad extension announcement
Goto Page: Previous1 2 3 4 5 6 7 8 9 10 11 Next
Posted by: jonibi | Date: 2007-05-06 14:34 | IP: IP Logged
I made an tutorial how to enable php debugging with pspad
This extension I made saves breakpoints from pspad bookmarks. Also you will need one firefox extension and php expert debugger
Edited 1 time(s). Last edit at 2007-05-06 14:35 by jonibi.
Posted by: hankejh | Date: 2007-06-14 18:01 | IP: IP Logged
Ingkcpos
Enhances CTRL+(SHIFT)+RIGHT/LEFT cursor position and text selection behavior.
REQUIREMENTS
Tested/compatible with PSPad versions:
-(full version) 4.5.2 (2240) - Windows XP/SP2
-(beta release) 4.5.3 (2262) - Windows XP/SP2
-(beta release) 4.5.3 (2265) - Windows XP/SP2
DOWNLOAD
INSTALL
1. If you installed a previous version, uninstall it by deleting these files:
~\PSPad editor\Script\JScript\CTRL+SHIFT+RIGHT.js
~\PSPad editor\Script\JScript\CTRL+SHIFT+LEFT.js
~\PSPad editor\Script\JScript\CTRL+RIGHT.js
~\PSPad editor\Script\JScript\CTRL+LEFT.js
2. Exit PSPad
3. Unzip the download and place files (ingkcpos.js and the README.txt) in:
4. Start PSPad
Additional notes are available on the project site sourceforge.net and within the comment header of the script.
Edited 1 time(s). Last edit at 2007-06-14 18:03 by hankejh.
Posted by: francheu | Date: 2007-06-14 18:52 | IP: IP Logged
New syntax file for Maxima.
This file has been created with version 5.11.
Some new keywords may have appeared since then.
Posted by: saue | Date: 2007-06-18 12:38 | IP: IP Logged
Syntax files for two of the most popular industrial robot manufacturer: ABB's RAPID and Fanuc's KAREL. Now available with PSPad. Get them here: www.pspad.com
Posted by: jonibi | Date: 2007-06-20 13:04 | IP: IP Logged
This extension enables your Pspad PHP projects to have 'Goto function definition' option, like in 'Eclipse' and 'Zend Studio'.
Edited 1 time(s). Last edit at 2007-06-20 13:04 by jonibi.
Posted by: hankejh | Date: 2007-06-28 15:40 | IP: IP Logged
Thanks to AndyBridges for killing the "modified flag" bug in the ingkcpos cursor enhancement extension.
The new version is now available in the usual place www.pspad.com.
Posted by: asifroyal | Date: 2007-07-09 09:42 | IP: IP Logged
Hay, This doesn't work. It does not indent using tab or indent by pressing Ctrl+ Alt+\ for the single line.
Posted by: hankejh | Date: 2007-07-17 19:39 | IP: IP Logged
The latest version (0.5) adds enhanced CTRL + RIGHT/LEFT cursor positioning support while working with files that contain non-ASCII characters.
Now available in the usual place www.pspad.com.
Please use the Sourceforge project page for requests/bug reports: www.sf.net
Edited 1 time(s). Last edit at 2007-07-17 19:40 by hankejh.
Posted by: pspad | Date: 2007-07-22 07:42 | IP: IP Logged
Thank you, I will include it into release
Posted by: sg | Date: 2007-08-04 21:45 | IP: IP Logged
Hi
I've just made an intellisense type of tooltips, which give you a hint of a functions options. It pops up automatically when you type in '(', or press CTRL+I (changable in the .js file). It uses the context file included with PSPad.
Install it by extracting the .js file to your scripts/jscript sub-directory, and extract the .dll file to wherever you want, then install it with 'regsvr32 PSPad_IntelliTips.dll'
It's a just quick hack I made for myself, and I'm releasing it in the hope that others may find it useful too. Source code is included, so feel free to do what you want with it.
Find it at www.grundell.co.uk/tips/
Ste
