You are here: PSPad forum > English discussion forum > PSPad extension announcement
Goto Page: Previous1 2 3 4 5 6 7 8 9 10 11 Next
#91 Hots 0.6 released
Posted by: alesc | Date: 11/21/2010 18:45 | IP: IP Logged
Hots 0.6 is released.
Hots is an utility made for developers who wants to use the power of various programming tools like Ctags (http://ctags.sourceforge.net) in PSPad freeware editor. (www.pspad.com) Hots is written in autohotkey and javascript scripts and provided to you in compiled form of an exe file.
New:
- Setup wizard enhancements(install/uninstall/repair/upgrade)
- Windows 7 support
- bug fixes
Check:
hots.sourceforge.net
#92 Code V 10.3 released
Posted by: francheu | Date: 05/15/2011 17:23 | IP: IP Logged
The syntax file and clips have been updated for Code V 10.3.
Download link: www.pspad.com
François
#93 Syntax definition : 3 new formats
Posted by: RhodonSylvain | Date: 07/31/2011 00:45 | IP: IP Logged
I made 3 new description file (first try sad smiley ):
- NMEA format (log GPS)
- GPX format for POI of GPSdash2
- PSpice library format (electronic simulator)
PSpice library (electronic simulator), NMEA (GPS log), GPX (POI for GPSdash)
#94 JSHint plugin
Posted by: pspadjshint | Date: 10/14/2011 10:29 | IP: IP Logged
I've made a nice JSHint plugin. It dynamically loads the jshint.js so when there is a jshint update you don't have to update this plugin.
You can get it here: github.com and click on one of the download buttons, or goto github.com and click on 'zip' or just download PSPadJSHint.js.
See ReadMe.MS for instructions how to install.
You can get jshint from github.com, click on one of the download buttons.
Edited 1 time(s). Last edit at 10/14/2011 10:29 by pspadjshint.
#95 Code V 10.4 released
Posted by: francheu | Date: 10/26/2011 17:23 | IP: IP Logged
The syntax file and clips have been updated for Code V 10.4.
François
Edited 1 time(s). Last edit at 10/26/2011 17:24 by francheu.
#96 Foobar2000 syntax
Posted by: tigermess | Date: 11/14/2011 23:10 | IP: IP Logged
Syntax for Foobar2000 v1.1.9 Tagz.
Included are DEF, INI, colors file and documentation.
http://www.mediafire.com/file/pb613srw30n0pin/PSPad-Foobar2000_syntax-v20111114.zip
#97 DirFiles
Posted by: arfelon | Date: 12/02/2011 12:22 | IP: IP Logged
DirFiles extension creates a list of all files from user defined directory recursively.
#98 Re: Ĉapeligu
Posted by: billps | Date: 02/15/2012 11:29 | IP: IP Logged
Does the extension come with Malware in the installer like PSPad does?
#99 PSPad extension announcement: New cpp class 0.1
Posted by: alesc | Date: 05/14/2012 07:56 | IP: IP Logged
Introduce new extension "New cpp class" which creates two files one cpp and one h file with some common code.
Download:
www.pspad.com
User can enter class name, base class, can change source file name, header filename, path to files and also use pspad templates to prepend it all with html dialog displayed with IE.
e.g. h file:
#ifndef MYCLASS_H
#define MYCLASS_H
class myclass : public baseclass
#endif // MYCLASS_H
e.g. cpp file:
#include "myclass.h"
Edited 1 time(s). Last edit at 05/14/2012 07:57 by alesc.
#100 PSPad extension announcement: New cpp class 0.2
Posted by: alesc | Date: 05/17/2012 20:45 | IP: IP Logged
New version now takes content for class files entirely from templates. Searches caseinsensitive in selected templates for some predefined words:
<sourceBasename>, <headerBasename>, <className>, <baseClassName>, <sourceFilename>, <headerFilename>
to replace with user entered data.
Ie form shows only cpp template files from PSPad template directory.
Download link:www.pspad.com
Sample cpp template:
* @file <sourceFilename>
#include <classname>.h
<className>::<className>()
Sample h template:
* @file <headerFilename>
#ifndef <headerBasename>
#define <headerBasename>
class <className> : public <baseClassName>
public:
<className>();
#endif // <headerBasename>
