You are here: PSPad forum > English discussion forum > Multi-Line Search Add-On
Goto Page: PreviousFirst...3 4 5 6 7 8 9 10 11 12 13 ...LastNext
#71 Re: Multi-Line Search Testers Needed
Posted by: MartyIX | Date: 2007-11-08 16:43 | IP: IP Logged
Is there anybody who can run this extension on Windows Vista? There's an error in phreplace.dll, which cannot be register.
#72 Re: Multi-Line Search Testers Needed
Posted by: vbr | Date: 2007-11-08 18:12 | IP: IP Logged
MartyIX:
Unfortunately, Vista doesn't seem to be supported (yet). See the notice of the author of this add-on:
forum.pspad.com
phdesigner:
I'm aware of a couple of issues still exisitng:
1. phReplace doesn't run on Windows Vista.
#73 Re: Multi-Line Search Testers Needed
Posted by: phdesigner | Date: 2007-11-12 04:52 | IP: IP Logged
New version of phReplace released 1.3.18.
This allows you to use backreferences ($1) on a single replace rather than just replace all.
Sorry I haven't got this working with Vista yet, I haven't got a copy of Vista to test with unfortunately.
Am I supposed to be able to edit my original post to update the latest version info? I don't seem to be able to edit my posts.
Cheers.
#74 Re: Multi-Line Search Testers Needed
Posted by: MartyIX | Date: 2007-11-12 11:04 | IP: IP Logged
And I suppose that it wouldn't help you to know what kind of error it crashes on, would it? It's some hexadecimal number.
#75 Re: Multi-Line Search Testers Needed
Posted by: pspad | Date: 2007-11-12 15:25 | IP: IP Logged
MartyIX:
I will replace memory manager. I hope it helps.
#76 Re: Multi-Line Search Testers Needed
Posted by: vbr | Date: 2007-11-12 15:32 | IP: IP Logged
Many thanks for the new version! The full support for backreferences in RE is really a great enhancement.
#77 Re: Multi-Line Search Testers Needed
Posted by: Stefan | Date: 2007-11-12 19:54 | IP: IP Logged
phdesigner:
Sure you should be able to edit your own post.
There should be an "Edit" link below every post..
#78 Re: Multi-Line Search Testers Needed
Posted by: MrSpock | Date: 2007-11-12 20:47 | IP: IP Logged
Stefan:
No, there isn't. It is there after submitting a post, but gets disabled after some time. At least this applies to "normal" users. Moderators can even edit other users' posts, I guess.
#79 Re: Multi-Line Search Testers Needed
Posted by: pspad | Date: 2007-11-12 20:55 | IP: IP Logged
You can edit your post about 60 minutes.
I think it's enough you are able to correct your post.
#80 Re: Multi-Line Search Testers Needed
Posted by: Stefan | Date: 2007-11-12 21:36 | IP: IP Logged
PSPad:
MrSpock:
Stefan:
Really ? sad smiley
Sorry i may mixed this up with other forums that are more niftier.
@Paul
you can send me an update of your first post or post an reply below.
Both i will use to update your first post.
Or i maintain your first post myself if you agree.
Edited 1 time(s). Last edit at 2007-11-14 21:10 by Stefan.
