You are here: PSPad forum > English discussion forum > Re: Multi-Line Search Add-On
Goto Page: PreviousFirst...7 8 9 10 11 12 13 14 15 16 17 Next
Posted by: carbonize | Date: 2012-12-19 10:17 | IP: IP Logged
OK for those having problems with it saying the dll not registered etc here's what I did. Simply run PSPad as admin. Find PSPad in your start menu or on your desktop, right click on it and select Run as Administrator. Once it has opened create a file then run Multiline Search/Replace. This should make it register the dll. Now close PSPad and run it as normal and it should work.
Carbonize
Posted by: Macari | Date: 2014-01-31 14:06 | IP: IP Logged
Search for multi-line is for me the most needed feature in a text editor. Its very a pity that great pspad this not have. :(
phReplace is old and can only replace text in actual text file or open files. Its not possible to add this in the standard "search&replace" and in "search&replace in files"? Is it correctly working with utf8 files?
I need it for a whole directory and subfolders. And I want set "code page". All this is not supported by phReplace.
Please add this as standard feature in PsPad like UltraEdit and another text editors already have.
Thanks for your hard work!
Posted by: erkange | Date: 2017-01-15 11:34 | IP: IP Logged
hello,
I have downloaded the files and put all of them under pspad folder.
But i can't find multiline search menu in pspad.
What is wrong?
OS : Windows 10
Pspad : 4.6.1
phreplace : 2.0.24
Posted by: erkange | Date: 2017-01-15 12:30 | IP: IP Logged
erkange:hello,I have downloaded the files and put all of them under pspad folder.
But i can't find multiline search menu in pspad.What is wrong?
OS : Windows 10
Pspad : 4.6.1
phreplace : 2.0.24
I also run these commands in cmd, but sill i can't see any scripts menu in pspad
regsvr32 D:\Programs\web\pspad461en_editor\phreplace.dll
regsvr32 C:\Program Files (x86)\PSPad editor\phreplace.dll
C:\Windows\System32>regsvr32 "phreplace.dll"
C:\Windows\SysWOW64>regsvr32 "phreplace.dll"
Posted by: pspad | Date: 2017-01-15 12:35 | IP: IP Logged
Please open and read PHReplace.vbs file.
Anyway, this file should be placed in the .\Script\VBScript folder
PSPad scripting should be enabled (program settings / System integration)
Multiline search/Replace as user script will be available in the Script menu
Posted by: erkange | Date: 2017-01-15 19:18 | IP: IP Logged
pspad:Please open and read PHReplace.vbs file.
Anyway, this file should be placed in the .\Script\VBScript folderPSPad scripting should be enabled (program settings / System integration)
I sense you are abit rude but anyway please find my reply below.
btw, thanks for solution.
Actually i have read it, no info.
i also read this page.
phdesign.com.au
There is no where saying that PSPad scripting should be enabled.
even i have read www.pspad.com this page.
You simply can add 1 more sentences there and anybody will learn how to use addon.
like this one
To use addons you must active integrated scipting. It is under settings > program settings > system intregration
STARTING PHREPLACE
To start phreplace, click on the Scripts menu in PSPad and select Multiline Search / Replace . A shortcut key can be assigned to phreplace, by default this is Ctrl-Alt-F. This can be changed in the phreplace startup script (phreplace.vbs
Edited 1 time(s). Last edit at 2017-01-15 19:19 by erkange.
Posted by: pspad | Date: 2017-01-15 20:17 | IP: IP Logged
erkange:I sense you are abit rude but anyway please find my reply below.
I am sorry, I am not a native English speaker. What do you consider as "rude"?
Posted by: Stefan | Date: 2017-01-19 09:56 | IP: IP Logged
erkange:I have downloaded the files and put all of them under pspad folder.
Also there is a overview at the first post of this thread.
Maybe that DLL doesn't work with Win10 anymore?
Do anyone use this Tool on Win10 and can report that it works?
THX
Posted by: Andreas | Date: 2017-01-19 12:45 | IP: IP Logged
Yes, it works on windows 10. Did you register the dll? See this post forum.pspad.com
Posted by: erkange | Date: 2017-02-04 09:12 | IP: IP Logged
Stefan:erkange:I have downloaded the files and put all of them under pspad folder.
But i can't find multiline search menu in pspad.pspad:Please open and read PHReplace.vbs file.Also there is a overview at the first post of this thread.
Do anyone use this Tool on Win10 and can report that it works?THX
I can confirm, it works
