You are here: PSPad forum > English discussion forum > How to change language on display?
#1 How to change language on display?
Posted by: motojosh | Date: 10/02/2006 10:58 | IP: IP Logged
Newbie to PSPad it looks nice, but all the controls are in a foreign language and I cannot read them to use the program. How do I change it to ENGLISH ??
#2 Re: How to change language on display?
Posted by: vbr | Date: 10/02/2006 11:38 | IP: IP Logged
Nastaveni / Nastaveni programu / Jazyk : English ...
#3 Re: How to change language on display?
Posted by: motojosh | Date: 10/02/2006 12:17 | IP: IP Logged
Ok, thanks I followed your direction, but I do not have English in that directory. Heres a screenshot>
I don't get it. Please help!!
#4 Re: How to change language on display?
Posted by: wal | Date: 10/02/2006 13:06 | IP: IP Logged
How do you install PSPad: using installer or manually copying files from CAB archive? In second case maybe you forgot to copy language files? Check PSPad folder. Here should be subfolder \Lang and it should contain language files. At least English.ini must be.
#5 Re: How to change language on display?
Posted by: motojosh | Date: 10/02/2006 13:36 | IP: IP Logged
The .cab folder has many files in it but no installer. I extracted the PSPad file to my desktop and that got my application running. Should I have extracted it within the same folder? There are no Sub-folders, just files within the .cab file
Edited 1 time(s). Last edit at 10/02/2006 13:40 by motojosh.
#6 Re: How to change language on display?
Posted by: wal | Date: 10/02/2006 13:49 | IP: IP Logged
.cab file has tree structure of files and folders inside. You should extract the all tree e.g. with 7zip www.7-zip.org
Edited 2 time(s). Last edit at 10/02/2006 14:02 by wal.
#7 Re: How to change language on display?
Posted by: motojosh | Date: 10/02/2006 15:34 | IP: IP Logged
Thanks guys, I got it. I had to RUN the file for the proper install. Sorry for that, it all seems to be working properly now.
