You are here: PSPad forum > English discussion forum > How to run my java-programs in PSPad
Goto Page: 1 2 Next
#1 How to run my java-programs in PSPad
Posted by: inkimar | Date: 09/19/2006 09:14 | IP: IP Logged
Hello!
How should I run my Java-programs in PsPad, setting the jsdk and where to hit run.
is there a step-by-step config somewhere ?
regards, Ink
#2 Re: How to run my java-programs in PSPad
Posted by: MrSpock | Date: 09/19/2006 12:36 | IP: IP Logged
A sample configuration that auto-runs console programs after compilation:
#3 Re: How to run my java-programs in PSPad
Posted by: Inkimar | Date: 09/19/2006 13:44 | IP: IP Logged
Thanks Mr. Spock!
Brilliant explanation. Did fill in all the stuff.
Did write a java-program, how do I launch this file ?
regards, i
#4 Re: How to run my java-programs in PSPad
Posted by: vbr | Date: 09/19/2006 14:55 | IP: IP Logged
Ctrl+F9
or Menu: File - Compile
or the respective button in the "Control" toolbar: "Run external compiler ... "
#5 Re: How to run my java-programs in PSPad
Posted by: Inkimar | Date: 09/19/2006 15:12 | IP: IP Logged
Hi!
Is there a minor-manual for this?
I mean, if I create a small project, how do I add my
jars from third-party deliverer and soforth !?
regards, i
#6 Re: How to run my java-programs in PSPad
Posted by: tenebro | Date: 09/21/2006 21:05 | IP: IP Logged
- Go to PSPad Help:
Menu description > Settings Menu > Highlighter settings > Compiler Settings
And
Menu description > Settings Menu > Highlighter settings > Compiler Settings > Compiler examples
- Try to use ANT (ant.apache.org) to add yours jars.
Best regards
Josue Rojas
#7 Re: How to run my java-programs in PSPad
Posted by: inkimar | Date: 09/26/2006 11:49 | IP: IP Logged
I am familiar with ant.
if using ANT; how do I set it up in pspad-env ?
regards,i
#8 Re: How to run my java-programs in PSPad
Posted by: johnas | Date: 11/07/2006 20:13 | IP: IP Logged
Another alternative to run the java interpreter:
cmd /c java.exe %Name% && pause
It will run the program in console, then will wait for a keystroke at the end. After that the console will be closed automatically.
#9 Re: How to run my java-programs in PSPad
Posted by: Lisa | Date: 01/09/2007 18:22 | IP: IP Logged
That command line to pause the command prompt window helps a lot! Thank you!
#10 Re: How to run my java-programs in PSPad
Posted by: pinkmoon | Date: 07/30/2007 05:17 | IP: IP Logged
Last two days i am using this PSPad.This is realy a good one.But,if i have to add third party JAR(link.jar) what should i do?? can u help me -- step by step.Thanks.Waiting for reply.
Goto Page: 1 2 Next
Editor PSPad - freeware editor, © 2001 - 2015 Jan Fiala
