You are here: PSPad forum > English discussion forum > Re: bbcode, phpbb-mode
Posted by: petitrot | Date: 2010-11-23 21:13 | IP: IP Logged
Hi
Thank fred_gaou
I taked a copy.
I have another script for BBCode in PSPad
A Plus with the PSPad_bbcode_addon.zip
bbcode_phpbb.js is a small file to place in the installation PSPad: PSPad/Script/JScript/bbcode_phpbb.js
Easy to use, to adapt for your use.
It's in french mais very simple to translate in an other language.
Instructions is in the header of the file.
Download: www.mediafire.com
This easy script is a good exemple of Howto for making some others goodies to use in PSPad
Let us know if you make some add or corrections
Edit : typo
Edited 1 time(s). Last edit at 2010-11-23 21:18 by petitrot.
Posted by: 007@pathcom.com | Date: 2010-12-29 22:47 | IP: IP Logged
The URLs no longer allow downloading of the zip file.
There is a link on Rapidshare, but I don't want to join.
I am also not sure whether the content of the zip when installed will enable PSPad to run the script and check for syntax errors.
I can of course do what I have always done, which is to run the script in a browser.
But it would be nice to be able to check the syntax in PSPad.
Thanks in advance for any help you can give.
Posted by: petitrot | Date: 2011-01-21 21:56 | IP: IP Logged
Mystara:Awesome! This is exactly what I wanted.Thank you!
Welcome
Hi 007
You want try it?
PSPad_bbcode_addon.zip, the last version is the same of the link from fred_gaou
www.mediafire.com
And the complement bbcode_phpbb.js, the link is www.mediafire.com
Today I check the 2 links and they are goods.
These scripts run very well from PSPad. Nothing to complain!
Easy to install in PSPad. At the start of PSPad, PSPad will find and analyse these files.
These files are for use in PSPad only, to edit in code bbcode only.
I'm using PSPad to edit the bbcode of this post. (just need to copy and put in the forum editor)
Posted by: R2-D2 | Date: 2013-01-07 01:07 | IP: IP Logged
Many thanks, I'v been looking for this for a long time.
Now I use PSPad for all my activities.
I would like like to note that on version 4.5.6 there is no more PSPad.ini, thus there is no need to edit anything.
Just put the correct files in the correct folders, open PSPad > Settings > Highlighter settings > select a bold one and choose BBCoode.
Then you only need to play a little with colors
This is how mine looks now:
Posted by: petitrot | Date: 2013-02-22 23:29 | IP: IP Logged
Hi
The link is broke for the complement BBCode in menu Scripts
Put the script in
PSPad\Script\JScript\bbcode_phpbb.js
Here it is:
BBCode PhpBB v1.0 - 14/10/2006
Version v1.0.1 - 10/01/2008
Version v1.0.2 - 2010
wow ataboy ''.phorum_html_encode('d_cuvilier@hotmail.com').'' subject: BBCode PhpBB v1.0.1
Inspired form the code of the Comments v1.0
Special Thanks to him
''.phorum_html_encode('maleval@gawab.com').''
2011-01-21
www.mediafire.com
PSPad BBcode Addon
You can read the message at the following page:
forum.pspad.com
Liens vers le fichier
www.mediafire.com
Ce script permet d'insérer les BBCode conformes PhpBB dans tous les types de
fichiers .bbcode, txt, html,... ouverts sous PSPad
Ce script, bbcode_phpbb.js, doit être placer dans le dossier d'installation
Si ces sous dossiers n'existent pas dans votre installation PSPad veillez les créer.
L'usage du script BBCode est disponible dans PSPad, menu Script, BBCode
Dans ce menu BBCode cliquer sur une sélection, insère automatiquement le BBCode
au niveau du curseur dans le fichier ouvert.
Le script BBCode fonctionne sous tous les types de fichiers .bbcode, txt, html,...
Le type de code utilisé pour ces BBCode sont conformes à la majorité des scripts
PhpBB v2. Si, sur votre site, vos BBCode sont différents veillez à adapter ce script.
Insérer BBCode conformes PhpBB
Insèrent des BBCode autour d'une sélection.
S'il n'y pas de sélection, les BBCode sont insérés à l'emplacement du curseur.
Supprimer les BBCode :
Recherche les BBCode dans la sélection.
S'il n'y a pas de sélection, recherche dans la ligne active.
Supprimer tous les BBCode :
Tous les BBCode sont supprimés. Préserve le contenu des BBCode.
Peut subsister quelques erreurs selon les BBCode utilisés!
Vérifier le résultat.
Supprimer tout (BBCode+contenu) :
Grand nettoyage. Supprime tous les BBCode et tout leurs contenus !
Peut être utile pour les forums qui valide l'usage de certains tags html
Pour toutes les actions Supprimer ...
Il peut subsister quelques erreurs selon les BBCode utilisés!
Toujours vérifier le résultat.
Testé avec PSPad 4.5.1 (2207) - Win XP SP2
Testé avec PSPad 4.5.4 (2356) - Win XP SP3
Ajout BBCode PhpBB 10/01/2008
, , , , [u], [/u], [strike], [/strike],[quote], [quote="n"],[/quote],[code],, [list], [/list], [img], [/img], [url], [url=n], [/url], , , [right], [/right], , , [face=n], [/face], [size=n], [/size]
Ajout BBCode PhpBB 17/05/2008
[email], [/email]
/* BBCode PhpBB InsertBBCode_Fr */
var module_name = "InsertBBCode";
var module_ver = "1.0.2";
var module_title = "BBCode";
/* [/b] */
function insertB_BBCode(){
var ceDoc = newEditor();
ceDoc.assignActiveEditor();
var s = ceDoc.selText();
s = "[b]"+s+"";
ceDoc.selText(s);
/* [/i] */
function insertI_BBCode(){
s = "[i]"+s+"";
ceDoc.selText(s);
/* [u][/u] */
function insertU_BBCode(){
s = "[u]"+s+"[/u]";
ceDoc.selText(s);
/* [strike][/strike] */
function insertSTRIKE_BBCode(){
s = "[strike]"+s+"[/strike]";
ceDoc.selText(s);
/* [img][/img] */
function insertIMG_BBCode(){
s = "[img]"+s+"[/img]";
ceDoc.selText(s);
/* [url][/url] */
function insertURL_BBCode(){
s = "[url]"+s+"[/url]";
ceDoc.selText(s);
/* [url=][/url] */
function insertURLN_BBCode(){
s = "[url="+s+"][/url]";
ceDoc.selText(s);
/*[quote][/quote]*/
function insertQUOTE_BBCode(){
s = "[quote]"+s+"[/quote]";
ceDoc.selText(s);
/* [quote=""][/quote]*/
function insertQUOTEN_BBCode(){
s = '[quote="'+s+'"][/quote]';
ceDoc.selText(s);
/*[/code]*/
function insertCODE_BBCode(){
s = "[code]"+s+"
ceDoc.selText(s);
/* [left][/left] */
function insertLEFT_BBCode(){
s = "[left]"+s+"[/left]";
ceDoc.selText(s);
/* [/center] */
function insertCENTER_BBCode(){
s = "[center]"+s+"";
ceDoc.selText(s);
/* [right][/right] */
function insertRIGHT_BBCode(){
s = "[right]"+s+"[/right]";
ceDoc.selText(s);
/* [color=][/color] */
function insertCOLOR_BBCode(){
s = "[color="+s+"][/color]";
ceDoc.selText(s);
/* [size=][/size] */
function insertSIZE_BBCode(){
s = "[size="+s+"][/size]";
ceDoc.selText(s);
/* [face=][/face] */
function insertFACE_BBCode(){
s = "[face="+s+"][/face]";
ceDoc.selText(s);
/* [list][/list] */
function insertLIST_BBCode(){
s = "[list]"+s+"[/list]";
ceDoc.selText(s);
/* [email][/email] */
function insertEMAIL_BBCode(){
s = "[email]"+s+"[/email]";
ceDoc.selText(s);
function insertSTAR_BBCode(){
s = "[*] "+s;
ceDoc.selText(s);
/* [mode hors sujet][fin hors sujet] */
function insertHORSSUJET_BBCode(){
s = "[mode hors sujet]"+s+"[fin hors sujet]";
ceDoc.selText(s);
/* Supprimer les Crochets [] vides */
function removeEmptyTags_BBCode(){
var r, s, flag = false;;
if (!s) {
flag = true;
s = ceDoc.lineText();
r = /\[\]|\[\/]|\[ \]|\[ \/]| \/]|\[ \/|/g;
var res = s.search(r);
if (res != -1) {
s = s.replace(r, "");
if (!flag) {
ceDoc.selText(s);
else {
ceDoc.lineText(s);
/* Supprimer tous les BBCode
selectionnes */
function removeTags_BBCode(){
if (!s) {
flag = true;
r = /\[\*\]|\[b\]|\[\/b\]|\[i\]|\[\/i\]|\[u\]|\[\/u\]|\[quote\]|\[quote=["\w\s]*|\]|\[\/quote\]|\[code\]|\[\/code\]|\[list\]|\[list=\]|\[list=a\]|\[list=A\]|\[list=1\]|\[\/list\]|\[img\]|\[\/img\]|\[url\]|\[url=|\[\/url\]|\[center\]|\[\/center\]|\[left\]|\[\/left\]|\[right\]|\[\/right\]|\[strike\]|\[\/strike\]|\[email\]|\[\/email\]|\[color=[\w\0-9#\s]*|\[\/color\]|\[size=[\0-9\s]*|\[\/size\]|\[face=[\w\s]*|\[\/face\]|\[\]|\[\/]|\[ \]|\[ \/]|/g;
if (res != -1) {
if (!flag) {
ceDoc.selText(s);
else {
ceDoc.lineText(s);
/* menu - sous-menu - script */
function Init(){
addMenuItem("-", "BBCode", "", ""); // Menu divider
addMenuItem("Insérer BBCode ", "BBCode", "insertB_BBCode", "");
addMenuItem("Insérer BBCode ", "BBCode", "insertI_BBCode", "");
addMenuItem("Insérer BBCode [u] [/u]", "BBCode", "insertU_BBCode", "");
addMenuItem("Insérer BBCode [strike] [/strike]", "BBCode", "insertSTRIKE_BBCode", "");
addMenuItem("Insérer BBCode ", "BBCode", "insertCOLOR_BBCode", "");
addMenuItem("Insérer BBCode [size=n] [/size]", "BBCode", "insertSIZE_BBCode", "");
addMenuItem("Insérer BBCode [img] [/img]", "BBCode", "insertIMG_BBCode", "");
addMenuItem("Insérer BBCode [url] [/url]", "BBCode", "insertURL_BBCode", "");
addMenuItem("Insérer BBCode [url=n] [/url]", "BBCode", "insertURLN_BBCode", "");
addMenuItem("Insérer BBCode[quote][/quote]", "BBCode", "insertQUOTE_BBCode", "");
addMenuItem("Insérer BBCode [quote=” “][/quote]", "BBCode", "insertQUOTEN_BBCode", "");
addMenuItem("Insérer BBCode[/code]", "BBCode", "insertCODE_BBCode", "");
addMenuItem("Insérer BBCode [face=n] [/face]", "BBCode", "insertFACE_BBCode", "");
addMenuItem("Insérer BBCode ", "BBCode", "insertCENTER_BBCode", "");
addMenuItem("Insérer BBCode [right] [/right]", "BBCode", "insertRIGHT_BBCode", "");
addMenuItem("Insérer BBCode [left] [/left]", "BBCode", "insertLEFT_BBCode", "");
addMenuItem("Insérer BBCode [list] [/list]", "BBCode", "insertLIST_BBCode", "");
addMenuItem("Insérer BBCode [email] [/email]", "BBCode", "insertEMAIL_BBCode", "");
addMenuItem("Insérer BBCode [*]", "BBCode", "insertSTAR_BBCode", "");
addMenuItem("Insérer BBCode [mode hors sujet]", "BBCode", "insertHORSSUJET_BBCode", "");
addMenuItem("Supprimer les crochets [] vides", "BBCode", "removeEmptyTags_BBCode", "");
addMenuItem("Supprimer tous les BBCode", "BBCode", "removeTags_BBCode", "");
addMenuItem("Utilisations", "BBCode", "infos", "");
addMenuItem("Editer ce script", "BBCode", "editMe", ""); // Edit this script in PSPad
addMenuItem("A propos", "BBCode", "about", ""); // About this extension
/* code emprunté du script ingkcpos
FILE: ingkcpos.js
VERSION: 0.5
WEB: www.sf.net/projects/ingkcpos
function infos()
/* Extension description, how to use, license,
open source project web address, and developer
credits.
echo(
"\n" + module_name + " " + module_ver + "\n\n" +
"_________________\n" +
"DESCRIPTION\n\n" +
" PSPad Editor extension\n" +
"USE\n\n" +
" Edit empty BBCode\n" +
" \n" +
" Edit BBCode around the \n" +
" text or lines selected.\n" +
" \n\n" +
" wow, ataboy\n"
return;
/* Editer ce script */
function editMe()
oEdit = newEditor();
oEdit.openFile(moduleFileName(module_name));
/* A propos */
function about()
credits.
echo(
"DESCRIPTION\n\n" +
" PSPad Editor extension to enhance the use\n" +
" of bbcode.\n\n" +
" Cette extention ajoute à l'éditeur PSPad l'édition \n" +
" de bbcode.\n" +
"EMPLOI\n\n" +
" Ajoute et/ou entoure de BBCode tout mot ou\n" +
" lignes sélectionnées dans un document.\n\n" +
" S'il n'y pas de sélection,\n" +
" le BBCode est inséré à l'emplacement du curseur.\n" +
"OPTION\n\n" +
" BBCodesHTML\n" +
" Nécessite l'emploi d'un module additionnel.\n\n" +
" Conversion bbcode vers html, Phil\n" +
" Convertir le document en source\n" +
" de page html complète.\n" +
" Pour visionner la page HTML dans PSPad,\n" +
" Menu HTML Prévisualiser page HTML.\n" +
"CREDITS\n\n" +
" minemule.free.fr\n\n" +
" MIT License\n" +
" Copyright (c) 2007 wow, Phil\n" +
" minemule.free.fr\n" +
" www.opensource.org/licenses/mit-license.php\t\t\n\n" +
" Developers: wow, Phil, La Mine Minemule Team\n"
return;
Posted by: carbonize | Date: 2013-02-23 12:26 | IP: IP Logged
Any particular reason the bold and italic bbcode do not have closing tags and no indication as to what they are in the menu?
Carbonize
Posted by: petitrot | Date: 2013-03-02 19:38 | IP: IP Logged
Thanks carbonize
I compared the posted script with the real script and find few others errors too.
I dont know where the bad lines from ? The parser of the forum ?
I retry to copy/paste the code from the real script.
I find it!! The problem is apparent in the Preview window of the post editor.
The code in the Preview part is not the code in the Reply part.
Ok! I will use bbcode trick/hack to gain a good code translate. The editor unlike the sequence []
Find and replace these lines :
/* [b][/b] */
s = "[b]"+s+"[/b]";
ceDoc.selText(s);
/* [i][/i] */
s = "[i]"+s+"[/i]";
ceDoc.selText(s);
/* [code][/code] */
s = "[code]"+s+"[/code]";
ceDoc.selText(s);
/* [center][/center] */
s = "[center]"+s+"[/center]";
ceDoc.selText(s);
And in the menu items, find and replace these others lines too :
addMenuItem("Insérer BBCode [b] [/b]", "BBCode", "insertB_BBCode", "");
addMenuItem("Insérer BBCode [i] [/i]", "BBCode", "insertI_BBCode", "");
addMenuItem("Insérer BBCode [color=n] [/color]", "BBCode", "insertCOLOR_BBCode", "");
addMenuItem("Insérer BBCode [code] [/code]", "BBCode", "insertCODE_BBCode", "");
addMenuItem("Insérer BBCode [center] [/center]", "BBCode", "insertCENTER_BBCode", "");
I will double check my inserts in the future...
Edit :
@carbonize The real code is intact in the source of the previous post.
forum.pspad.com Date: 02/23/2013 00:29
Not in the source html but in the source of the post = in the sql base.
I find a way to copy the exact code posted in the previous post.
Dont direct copy the script from the window, this is a modified version from the forum parser.
Click the Option: Reply and you will see the exact code posted whitout a modification from the parser.
@pspad That was good to know...
Edited 1 time(s). Last edit at 2013-03-02 20:02 by petitrot.
Posted by: carbonize | Date: 2013-03-03 10:37 | IP: IP Logged
You could always upload it to somewhere like Pastebin
Carbonize
Posted by: Anderson85 | Date: 2021-04-05 05:42 | IP: IP Logged
What type of topics can be posted here, what things we can post in off-topic boards?
Posted by: pspad | Date: 2021-04-05 06:00 | IP: IP Logged
I don't understand your question. What exactly do you want to post as offtopic?
To be honest, I am not PHP programmer and any changes in this forum takes me very much time. I am glad it works in current way.
Edited 1 time(s). Last edit at 2021-04-05 06:01 by pspad.
