You are here: PSPad forum > English discussion forum > autocorrect
autocorrect
Goto Page: 1 2 Next
#1 autocorrect
Posted by: azleam | Date: 2006-07-07 13:53 | IP: IP Logged
hello
I want pspad to realtime autocorrect text as I type, by replacing specific text with other text that I configure
is it possible?
thanks
PS: something like realtime-as-you-type-search-and-replace
Edited 1 time(s). Last edit at 2006-07-07 13:54 by azleam.
#2 Re: autocorrect
Posted by: pspad | Date: 2006-07-07 15:57 | IP: IP Logged
menu settings / Spell settings
There is a autocorrect list
#3 Re: autocorrect
Posted by: azleam | Date: 2006-07-07 16:42 | IP: IP Logged
thanks for your reply
I set it to autocorrect:
<space><space> with <space>
<space>se with <space>sa
and it doesnt work
is there a way I have to enable it? (I have checked 'active' box)
#4 Re: autocorrect
Posted by: pspad | Date: 2006-07-07 17:52 | IP: IP Logged
autocorrection doesn't work with a spaces
#5 Re: autocorrect
Posted by: User | Date: 2006-07-07 19:46 | IP: IP Logged
Where is the trick to use auto correction ?
I add the expression "msg" and replace with "msgbox".
Active is checked.
When I enter "msg" nothing happens, "msg<space>", "msg<enter>".
Nothing...?
#6 Re: autocorrect
Posted by: User | Date: 2006-07-07 19:53 | IP: IP Logged
Ok, sorry, the solution is:
I must restart PSPad, otherwise new added expressions won't be replaced...
#7 Re: autocorrect
Posted by: azleam | Date: 2006-07-07 22:29 | IP: IP Logged
it would be a very nice feature to use regex in autocorrect
do you have any intention to implement it?
thanks
#8 Re: autocorrect
Posted by: pspad | Date: 2006-07-08 05:49 | IP: IP Logged
autocorrection is fired by the whitespaces (space, tab, enter)
I don't know if implementation of the regular expression should be advantage in this case.
#9 Re: autocorrect
Posted by: Esgrimidor | Date: 2014-07-25 14:59 | IP: IP Logged
I have interest know if this implementations is partially adopted or not .
Best Regards
Nice program indeed
#10 Re: autocorrect
Posted by: pspad | Date: 2014-07-25 15:02 | IP: IP Logged
Regular expression in autocorrect are not implemented.
Can you give me examples of usage?
Goto Page: 1 2 Next
