You are here: PSPad forum > English discussion forum > Re: Current Line Highlighter obscures current line
Posted by: TimMott | Date: 2006-02-24 06:12 | IP: IP Logged
In some of my color schemes I require a dark background with light text on some lines.
However, the highlight for the current line replaces the dark background with a light background, without compensating for the text. This makes the line unreadable. Is there a way to fix this? (Apart from changing my colour scheme)
Thanks,
Tim
Posted by: pspad | Date: 2006-02-24 09:12 | IP: IP Logged
You can change highligh color and font in the program settings
Posted by: TimMott | Date: 2006-02-24 16:47 | IP: IP Logged
I know I can change the font colours -- I asked if there is a way to fix the problem without changing my scheme.
Specifically, here are the colours causing me a problem:
Background: rgb(138,26,13)
Font: rgb(255,228,179)
and Current Line: rgb(255,240,213).
I do not want to change these colours. These particular colours highlight
preprocessor commands in my C++ scheme. However, the current line
completely obscures the text on these lines.
Is it not possible for PSPad to detect the low contrast and automatically
change the text colour? (e.g. to rgb(0,0,0))
Tim
Posted by: julianbiggio | Date: 2013-05-24 00:57 | IP: IP Logged
Solution:
1) Go to Options/Options.
2) Press the button advanced edition
3) Set ActiveLine=0
And now, the active line has no color =).
Posted by: pspad | Date: 2013-05-24 05:18 | IP: IP Logged
In the near future will be possibility to set current line color in highlighter color settings. You will be able customize current line color and font individually for each highlighter.
Posted by: pspad | Date: 2013-05-24 05:37 | IP: IP Logged
julianbiggio:Solution:
3) Set ActiveLine=0And now, the active line has no color =).
This option is in the View menu as Current line
