You are here: PSPad forum > English discussion forum > Thread for links to further informations
Goto Page: 1 2 3 Next
#1 Thread for links to further informations
Posted by: Stefan | Date: 11/05/2004 13:59 | IP: IP Logged
This thread is meant for posting usefull links around our favorated editor
and also to programing languages.
No spam please.
See also my inofficial FAQs
See also Special Settings List
Edit:
edit furter to further
Post Edited (01-14-2005 18:38)
greets, Stefan
image (pleased user since 1722)
inofficial FAQs + Infos + Special Settings
Edited 7 time(s). Last edit at 01/20/2007 08:31 by pspad.
#2 Re: Thread for links to furter informations
Posted by: Stefan | Date: 11/05/2004 14:02 | IP: IP Logged
For your information only....
Active FTP vs. Passive FTP, a Definitive Explanation
Introduction
One of the most commonly seen questions when dealing with firewalls and other
Internet connectivity issues is the difference between active and passive FTP and
how best to support either or both of them. Hopefully the following text will help to
clear up some of the confusion over how to support FTP in a firewalled
environment. more...
Post Edited (11-22-2004 12:47)
greets, Stefan
#3 Re: Thread for links to furter informations
Posted by: Stefan | Date: 11/05/2004 14:15 | IP: IP Logged
What is a Winsock error?
When using any TCP/IP application, such as an email reader, web browser, telnet
client or Secure Shell client, it is possible for numerous errors in both configuration
and networking, to occur.
Here are some lists of possible error codes:
Common Winsock API Error/Status Messages also to solving "PSPad" FTP errors, e.g."LastError: 11001" or so
List of Error/Status Messages
The following is a list of possible error codes along with their extended explanations. more...
Platform SDK: Windows Sockets
Windows Sockets Error Codes
The following list describes the possible error codes returned by the WSAGetLastError function read more...
Post Edited (11-22-2004 12:50)
greets, Stefan
#4 Re: Thread for links to furter informations
Posted by: Stefan | Date: 11/07/2004 15:46 | IP: IP Logged
PSPad use Synapse code for his FTP client.
Synapse
Lukas Gebauer
author of code for PSPads FTP tool
Project idea:
The SYNAPSE library aims to create a complete library of classes and functions
that would markedly simplify application programming of network communication
using Winsock. more...
Post Edited (11-22-2004 12:46)
greets, Stefan
#5 Re: Thread for links to furter informations
Posted by: Stefan | Date: 11/07/2004 15:52 | IP: IP Logged
synedit.sourceforge.net
PSPad is written in Borland Delphi 7 and based on SynEdit
SynEdit is an advanced multi-line edit control, for Borland Delphi,
Kylix (Kylix is supported into latest cvs) and C++Builder.
It supports Syntax Highlighting and code completion,
it does include exporters for html,tex and rtf. more...
Edit 2004-12-21:
Author: pspad
Date: 11-08-2004 05:49
Base component SynEdit doesn't support search/replace over several lines.
Author: pspad
Date: 11-12-2004 13:44
Resend mail from synedit developer forum:
Mal Hrz:
We have three bugs left, 1041595 doesn't seem to be very critical.
I think these are definetly the last ones we should fix before the comming
stable.
I hope in near future will be stable release of Synedit and most of problems with wordwrap will be removed
Edit 2005-06-12:
Author: pspad (---.brno.tiscali.cz)
Date: 06-12-2005 17:41
> By the way, what version of Synedit used in PSPad 4.3.2 [2042] ?
Synedit 1.288 2003/08/31
Because next synedit version (Slavio Etrusco rewrite Synedit plugin systems)
break support of SpellCheck and bring other problems.
After next release I start implementation of UniSynedit mh-nexus.de
Post Edited (06-12-2005 22:04)
greets, Stefan
#6 Re: Thread for links to furter informations
Posted by: Stefan | Date: 11/22/2004 15:22 | IP: IP Logged
Author: Lucas (---.nsw.veridas.net)
Date: 12-12-2004 12:45
PSPad works great using wine on Linux.
you dont even need anything special to be installed,
just run the installer and it does the rest.
Post Edited (12-19-2004 21:10)
greets, Stefan
#7 Re: Thread for links to furter informations
Posted by: Stefan | Date: 12/19/2004 13:48 | IP: IP Logged
Introduction to the Windows Registry
What is the Registry?
To many the Windows Registry is a mysterious forbidden zone,
a place they dare not tread. The registry, however, can be a powerful tool
for customizing Windows. If you've avoided the registry in the past,
it may be time to put your fears behind you and find out
what the registry can do for you.
This article is a basic tutorial on what the registry is and how it functions read more...
greets, Stefan
#8 Re: Thread for links to furter informations
Posted by: Stefan | Date: 12/19/2004 21:20 | IP: IP Logged
PSPad converter ROT47
forum.pspad.com
HowTo - some RegEx for you
forum.pspad.com
[for you] META Tag generator for PSPad
forum.pspad.com
For you: Font names for html.def
forum.pspad.com
For you: Color names for html.def
forum.pspad.com
[how to] change Date format for insert in text (ALT+D)
forum.pspad.com
[new feature] ROT13
forum.pspad.com
[b]
Post Edited (07-22-2005 18:45)
greets, Stefan
#9 Re: Thread for links to furter informations
Posted by: Stefan | Date: 12/28/2004 08:51 | IP: IP Logged
Author: pspad
Date: 12-16-2004 12:00
PSPad beta forum info is available as RSS 2.0
you can try it at www.pspad.com
In RSS are published only main topics - info about new version with changes To original thread...
- - - U P D A T E - - -
Author: pspad
Date: 07-16-2005 17:50
Subdomain http ://rss.pspad.com will be removed
Please all who are using PSPad RSS channel from rss subdomain,
change address to: www.pspad.com/rss/rssen.php
Thank you
image ? For RSS novice users...
What is RSS?
by Mark Pilgrim
December 18, 2002
RSS is a format for syndicating news and the content of news-like sites, including
major news sites like Wired, news-oriented community sites like Slashdot, and personal weblogs.
But it's not just for news. ? read more...
image ? F? Anf䮧er...
Was ist RSS?
RSS ist ein praktikabler XML-Standard, um Meldungen oder Textinformationen f?ndere Rechner zur Verf?zu stellen. Anders als bei einer im Browser
abrufbaren Website, wird in einer RSS-Datei die Information auf den Inhalt
reduziert und logisch gekennzeichnet, so dass sie von Maschinen interpretierbar ist. ? lies weiter...
Post Edited (07-17-2005 20:44)
greets, Stefan
Edited 2 time(s). Last edit at 05/21/2006 00:33 by pavel.
#10 Re: Thread for links to furter informations
Posted by: Stefan | Date: 01/01/2005 17:28 | IP: IP Logged
Binary versus ASCII (Plain Text) Files
The Difference Between Binary and ASCII Files
At heart all files are binary files -- that is, a collection of 1s and 0s.
But there's a subset of binary files we call ASCII, or plain text files.
Let's look at some example - different file types containing the word 'hello'
followed by a new line. To see the differences, we will use a hex display,
to show us exactly what is in each file, and highlight the word hello in the output
so we can see where it appears. read more...
greets, Stefan
Editor PSPad - freeware editor, © 2001 - 2015 Jan Fiala
