You are here: PSPad forum > English discussion forum > copy/paste mode issues
#1 copy/paste mode issues
Posted by: wim | Date: 07/28/2005 10:33 | IP: IP Logged
A few questions / feature request:
With Alt-Mouse you can select a rectangle to copy etc.
1. How can I switch to this mode and back with cursor keys? (In Borland you use Shift-Alt-cursor keys).
2. In this mode (in Borlands CBuilder), when you paste, the cursor is moved to the next line. This allows you to quickly insert some text on several lines. Is this possible?
Thx, wim
#2 Re: copy/paste mode issues
Posted by: Stefan | Date: 07/28/2005 12:14 | IP: IP Logged
- Hold ALT-Key and select column with mouse and left button.
- See also "Settings | Program Settings | Editor behaviour "
- And try "Edit | Selection type"
- Try also to press F1 in PSPad.
greets, Stefan
image (pleased user since 1722)
inofficial FAQs + Infos + Special Settings
